Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 48
Thread: Remote laptop startup
  1. #31
    Feb 2005
    TEXAS
    does anybody just make a USB power button? Wait, that would be to easy
  2. #32
    Nov 2005
    most laptops power down the usb ports when off/hibernating
  3. #33
    Mar 2004
    Back to your original loopback issue on the Intel card(I know that was a loooong time ago, but thought the info might be helpful.
    It is probably not working with the loopback because the card is set to auto-negotiate speed.
    Go to the adapter settings, and force either 10M or 100M, and I bet it works. I use loopbacks on my toshiba laptops to force alternate network configs for some software we use that requires an IP, and I couldnt get the loopback to feign a link til I did this.
  4. #34
    Quote Originally Posted by Farrow099
    Vista supports resume from hibernate with USB keyboards so it must be possible to leave the appropriate USB port on. that that would do to your battery life (laptop or car or both depending on your config) remains to be seen.
  5. #35
    Quote Originally Posted by thonl
    I'm about to try to get wake on link working with a Motion LS800 Tablet PC and docking station. Can someone clarify what the pin numbering scheme in post 1 is? I see 8 gold connectors when looking at the connector on the end of network cable. So looking down directly at those with the rest of the cable itself hanging down from there, which is pin 1?
  6. #36
    Never mind. After I failed searching mp3car.com, Google pointed me back at mp3car.com:
    Power On laptop at start
  7. #37
    Dec 2006
    ur answer
    Have u tried looking for a BIOS update? flashing that BIOS with a new version might give you the capabilities you want for your nic! give it a shot
  8. #38
    Nov 2006
    Your idea worked great on my T21 too. THANKS!!
  9. #39
  10. #40
    Jan 2007
    VA,USA
    Wink
    Quote Originally Posted by ambush View Post
    I'm planning to use a Thinkpad T23 laptop for my car-PC and I'm currently working on the automatic startup/shutdown. My plan is to buy a 12V car adapter for the laptop and connect that to the ignition. That way, the laptop will have power only when the ignition is on. Then I will configure XP to standby once the ignition turns off and the laptop goes to battery power (can be done by configuring the XP power settings). However the big kahuna has been how to make the laptop automatically resume upon ignite. So far, WOL (Wake-On-Link) seem to be the way to go. WOL will resume the system from standby when the configured network interface has link. To test this, I made a small loopback adapter consisting of a RJ45 plug where I connect pin1 to pin3 and pin2 to pin6. Then I enabled WOL on the NIC (Network Interface Card) (the advanced tab on the NIC configuration dialogue accessed from the network connection properties) and marked the box to allow that NIC to resume the system from standby (done under power settings in the NIC configuration dialogue).
    I tested this on an IBM Thinkpad T20 (3Com 10/100 Mini-PCI NIC) running W2K and it worked flawlessly from standby. Couldn't test hibernate though as the PC was running PointSec software that is incompatible with hibernate functionality.
    I then tried this on a Thinkpad T23 (Intel Pro 10/100 VE NIC) running XPPro but that did not work. At first, the NIC driver did not support WOL so I downloaded the latest version of the driver from Intel. XP would not accept that driver automatically so I had to force it. After a reboot, I had the Wakeup settings under the NIC properties so I set it as on the T20 laptop but this time no go. The laptop would not resume when I inserted my loopback adapter in the NIC.
    I attribute this purely to software issues. The BIOS power settings on the laptop are only applicable when the laptop is running APM software. Microsoft W2K and XP are using ACPI where all powersettings are software configurable, thus rendering the BIOS power settings mute. So wether or not WOL works is a matter of NIC driver functionality and so far it seems that 3Com drivers support this feature and Intel drivers do not (although it looks like they should).
    If I get it to work, it's a small thing to take two relays, controlled by the ignition switch, to bridge those four pins in the NIC slot to resume the laptop from standby. Haven't had the possibility to try it in hibernate mode but I guess as it is OS controlled it will not work because in hibernation the laptop is completely shutdown and thus, any OS functions will not run.
    It would be nice to know if anyone else has fiddled with this and actually got it to work (with an Intel NIC).
    This may be helpful:
    "I went into the properties of the NIC (Intel Pro/100 VE Network Connection) in Device Manager and found some tabs, one of them being Power Management. In there I could select to enable or disable Wake on LAN (among other things, such as Wake on Direct and Wake on Link -- Wake on Direct turns the computer on if another computer tries to browse its files -- which might be useful to some people -- Wake on Link turns the computer on if the link goes down while the computer is off and then comes back up)."
  1. Remotely startup laptop...? (wake on lan)??
    By Pro in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-13-2006, 07:57 AM
  2. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 11:52 PM
  3. Remote range increase for remote startup
    By EBFoxbat in forum General Hardware Discussion
    Last Post: 09-04-2004, 07:17 PM
  4. Laptop Startup
    By prophet in forum Power Supplies
    Last Post: 07-10-2004, 01:53 PM
  5. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
