ok, maybe $12 is a slight exageration ;) but I've bought faster laptops that actually work to an outside screen for not much more than $100, your hardrive is probably worth $40-$50, & the remainder isn't going to bring much at all. at 333 mhz you can buy a whole working laptop,with a complete working screen & all for around $150-$160 on ebay, if you search for "broken lcd" or "cracked screen" or a combination of this on ebay in laptop section you will find good working faster laptops on ebay cheap enough, & I happen to think this is an excellent way to put a pc in a car cheap, although in the end it's not a whole lot more to do it with a pc, & the benefits are better expandability & the biggest thing is not having to reach the laptop switch to boot, although some have had success relocating the switch, it depends on the actual laptop design. I had a panasonic toughbook in one of my installs, & I was able to mount an actuator along side it to "pull" the switch foward to boot with a remote mounted switch.
If you search ebay long enough you can find like a 1.8-2.4 with video in & out, dvd drive etc. with a busted screen but working in the $200-$250 range, good luck...
cool... i was only planning to use this labtop as a temporary till i have money for a better setup but since it doesnt even work and its not worth fixing it up i thought i would sell it but it seems like i cant get much for it...
yea your are probably better off keeping it, or at least using some of teh parts (harddrive... dvd.. etc)
i think i can only use the dvd rom and the harddrive... other then that everything else is junk...
LAP LAP LAP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!
...what can you do with the dvd drive?? unless you have another laPtop the same?...
