Results 11 to 20 of 29
Thread: Shutdown Controller and Laptops
  1. #11
    Jul 2004
    Are there any concerns with laptops and cranking your car?
  2. #12
    Dec 2003
    Surrey, BC, Canada
    If the laptop has a battery installed, cranking should not be an issue (it would be like pulling the plug for a second then plugging it back in).
    As for wiring, it's pretty simple. Here's what you'll have to hook up for MOST shutdown controllers (read the instructions for your SDC carefully first!):
    -constant power IN, should be directly from the battery
    -switched power IN, eg. the ACC line, this tells the controller when to send the on/off pulses to the power button
    -ground
    -power OUT, this will be going to your inverter so that your laptop can be charged by the inverter
    -(may or may not be) ground "OUT" for the inverter, you may also just ground the inverter to the chassis (remember to use a single ground point for everything)
    -2 pins for your ATX switch, these go to the power button that you've soldered on to, polarity should not matter so either pin goes to either pad on the button
    Hope that makes sense and helps you a bit.
  3. #13
    Jul 2004
    thanks!
  4. #14
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Ok, so what if my battery cannot hold a charge anylonger, and I can't buy a new one right now?
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  5. #15
    It may not be an issue if you are using an inverter. If it is, you could use our tank circuit with a sealed lead acid battery.
    KyferEz
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
  6. #16
    Dec 2003
    Surrey, BC, Canada
    KyferEz, I don't mean to be a dick here but I think you should stop "helping" people by advertising your products. MP3car.com is a retailer and probably wouldn't appreciate a competitor advertising on their site...
    Unless you already have authorization by the owners to do so, in that case I really am a dick.
    Anyway, LinuxRacr, if you don't have a battery and the voltage drops below the inverter's minimum input during your crank, then it will shut off. Although, if your battery holds enough charge to keep the system alive even a few seconds you may be able to get through a crank.
  7. #17
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    moahdib, just wanted to ask a couple questions, first of all....do you have an invertor, or just a dc adapter......basically i'm asking if you docking station takes an AC or DC input, i know all of the new IBM docks in my office are AC power and dont use the laptop dc power supply. Also.........wouldnt the standard ITPS work as a shutdown controller for a laptop perfectly? I was thinking of using one to regulate power for a LCD in a buddy's car, and using it to controll startup/shutdown for a laptop through a dock.
    PC Components:
    My work log
  8. #18
    Jul 2004
    "if your battery holds enough charge to keep the system alive even a few seconds you may be able to get through a crank."
    If your laptop is in hibernation mode why is the battery an issue?
  9. #19
    Quote Originally Posted by Bobby Digital
    Yes, I do. In fact, they are a distributor of our Power Controllers
    KyferEz
    Copper Wire Data
  10. #20
    Jul 2003
    My battery holds 0 charge. Not even a second's worth of charge. It is just there to continue the circuit (extra weight). I have a 400 Watt Coleman inverter and also a DC-DC power adapter that does 19v too that I got off ebay. Now what are my options?
    Current build! Here
  1. Laptop Startup/Shutdown controller
    By jonee in forum Power Supplies
    Last Post: 12-09-2011, 10:36 AM
  2. Controller + inverter for Toshiba LTM10C321A?
    By Arathranar in forum LCD/Display
    Last Post: 10-05-2004, 07:28 PM
  3. Startup pulse fix with Jeff Shutdown Controller
    By moahdib in forum Power Supplies
    Last Post: 03-03-2004, 12:51 PM
  4. Need an LCD controller for ex laptop display
    By MGP3Car in forum LCD/Display
    Last Post: 08-31-2003, 07:14 AM
  5. latop lcd screen with controller card?
    By schrodos in forum General Hardware Discussion
    Last Post: 11-20-2000, 11:34 AM
