take apart your laptop apart and wire it in parrarel to the button that turns your laptop on
Can someone explain how I would wire up one of those shutdown controllers to send my laptop into hibernation (i.e. wired to the power button on my laptop and or a docking station)?
I was thinking about using the uSDC20D micro Shutdown Controller. I understand that a wire has to go to ground, another wire has to go to the ignition, and another wire has to go to the car battery (positive).
The part that is confusing is how to wire it to the power button on the laptop when the controller is made for ATX computer/power-supply.
So far - 1.1ghz athlon 4 Sharp Laptop, 256mb RAM, 20GB HDD, 32MB on board graphics. CDRW/DVD, 600W Boschmann amp, K301 InDash Screen
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
I have a Sony laptop and a Dell and neither of them have jumper-style pins like an atx motherboard, just pads that the button is soldered to. I ended up using the Dell in the car and had to solder wires to the pads and extend them outside of the laptop case to hook up to my shutdown controller.Originally Posted by moahdib
So, to the original poster, you have to take it apart and look where the power button is hooked up to. If it's just pins then you lucked out and you can hook it up to that, otherwise you might have to do some soldering.
There are also shutdown controllers available that can shutdown via the serial port and some software (eg. DSSC), but these I don't think there is a startup option when you use it like that so you will have to setup the laptop BIOS to resume on power loss (if it has that option in BIOS).
I want to know as well. I have a HP Pavilion N5190 Laptop with docking station for my project. I am almost done, and this is one of the final touches to complete my project.
Our shutdown controller will do serial port shutdown, so you don't need to open the laptop. When using serial port shutdown, you do have to turn on the PC by yourself though.
Check it out, it is so much more than just a simple shutdown controller.
KyferEz
TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
PSU Wattage Calculator
Electronics Calculators
Copper Wire Data
Whichever controller I use has to be able to startup the laptop. I just wish I knew more about electronics...![]()
Well, our controllers can fully control a laptop, however, you will have to connect to the laptop's pushbutton. Likely this will require soldering wires onto the pins of that pushbutton.
KyferEz
Copper Wire Data
