Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Laptop Statup/Shutdown/standby/hibernate question
    Oct 2005
    Im very new to this and just came across a laptop with a broken screen a nice 2ghz 512ram 60gig hard drive wireless...You get the picture i was just going to machine a mount and mount it under my seat in my truck then run the VGA out to a touchscreen Xenarc in my dash...Alsmot seems premade for my purpose but i was just wondering what i could do to get it to have automatic shutdown startup hibernate and the like just as if i was using one of those fancy car PSU's anyone that may help or give insites ect would be GREATLY appreciated !! thanks again
    Nate
    Constant Bitrate thunderdepot's Avatar
    Sep 2005
    I have somewhat the same question. I have an extra IBM 390X Laptop laying around and want to use that as my temporary carputer until I get enough money to build a normal carputer. I bought the Xenarc 700IDT as a screen.
    But how do I get it to turn on if it is in my trunk? I heard about wake on ring and shorting out wires. Any step by step tutorials or an easy solution for a noob? I already figured out how to make it go in to hibernation automatically after my car turns off just need to figure out how to get it to turn back on. Switch, automatically, etc?
    Sep 2005
    *bump*
    Oct 2004
    Before I sold my Thinkpad T20 I had an idea of using it as a carputer. I never came around to actually do it but I looked into this startup/shutdown issue using laptops. I found that the network interface in the T20 (3com mini-PCI I believe) supported WOL (Wake-on-Link). The NIC in my T41 laptop does not support this feature fully so it's pretty much a case-by-case issue wether the NIC support WOL or not.
    Anyway, WOL works so that as long as the NIC has active link, the laptop runs as usual. Once the link goes down, the laptop goes to standby (by setting this in the power settings in XP). When the link goes active again, the laptop resumes from standby mode. I actually went out and bought components to build a relay that connects to the ignition and gives active link when ignition is on and disables the link when ignition is turned off. To test, just loop RxD and TxD pins in the ethernet port of the NIC, set the WOL and power settings and remove the loop. The laptop should now go to standby and when You loop it again it should resume.
    I dunno wether the 390X has a built-in NIC but if not, I would recommend using a 3COM PCMCIA NIC as these cards seem to support WOL in most cases.
    ich bin anders...
    Mar 2005
    check out my install (my sig). I used a docking station and extend the power botton
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    Come on guys, read the FAQs and run some searches...
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    Fusion Brain Creator
    Mar 2005
    surprise!
    gbh
    gbh is offline
    Constant Bitrate gbh's Avatar
    Oct 2005
    Massachusetts, USA
    Sorry - but i've always wanted to do that!
    It really depends on your specific laptop, your bios, and how you want it to work.
    Do you want to wake it from S1, S2, S3, S4?
    My laptop supposedly supports WOL, WOR,and WOUSB. I configured for WO USB but it kept cutting power to USB so it would not wake. (yes I set the option to not cut the power). I tested wake on ring but it did not work either. WOL seemed like a lot of work and I didn't have any faith that would work either. I finally decided soldering wires to power switch(there is no port replicator for my laptop) was best for what I wanted anyway.
    Wiring to power switch wakes laptop from all standby states, from hibernate and will turn it on from off. Also I can hit the switch and the laptop will go to standby. I wired laptop power switch to 1/8 audio connector that I put where the port replicator connector would have been - so I can disconnect and take laptop out of the car easily.
    All The information is out there if you search. You need to determine what is best for you and what can be implemented on your laptop.
    Good Luck!!
    Sep 2005
    San Luis Obispo, CA
    His first and only post.. I'm shocked.
    -arebelspy
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Hehe,
    Here's something weird.
    My laptop (Dell Latitude L400) has a Wake On-Modem Ring, but it's disabled in the BIOS. If I can get this enabled, is there a way that I could use this for my autostart?
    Peace,
    Rafster
  1. Replies: 47
    Last Post: 05-03-2005, 01:28 PM
  2. Laptop vs desktop
    By wei2cool in forum General Hardware Discussion
    Last Post: 03-17-2005, 06:25 PM
  3. Replies: 3
    Last Post: 12-02-2004, 05:00 PM
  4. quick question re: laptop power
    By mkerr in forum Power Supplies
    Last Post: 10-22-2004, 12:37 AM
  5. display and laptop question
    By jstrain in forum General Hardware Discussion
    Last Post: 04-04-2000, 01:05 PM
