Results 1 to 10 of 20
Thread: why does my laptop turn on?
    Sep 2005
    this is a weird one that I havn't been able to explain...
    I used to use an inverter to power my laptop with the AC-DC adapter. I had it set up so that the laptop would go into hibernate when power switches to battery, all good works great. When I start my car up, I have to press the power button to start the laptop, which was fine and dandy - expectable, because there is no "auto turn on" feature with a laptop.
    Here's whats weird:
    I got rid of the inverter, because It seemed un-necessary to convert power to ac and then back to DC, so I bought a DC- DC adapter on ebay ( generic )
    I installed it, and voila 19-20v of 90 watts to my laptop from the 12V ignition. YAY.
    The thing is now whenever I start my car, my laptop mysteriously automaticaly turns on and out of hibernate. Even when I shut down the laptop completely, when power is applied- boom there's the boot up screen...
    now in NO WAY am I complaining about this, this is veryyy convenient, and im glad that it does this... the only thing that irks me is I can't explain it! I didn't change any of the power settings in the bios...not that there is any.
    THe only thing I can think of is a weird surge from the DC adapter... but still, this doesn't connect to the power button at all!
    Any ideas?
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    it might be that you laptop isnt fully switched off when the power is killed, sometimes in a laptop bios you will find a auto on with power fail.. so it might think u had a power fail.. if you see what I mean.. this is the only thing I can think of at the mo
    cdr
    Maximum Bitrate DeltaFX's Avatar
    France
    Yep, it looks like a "resume on power loss".
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If "resume on power loss" is the cause, why didn't it happen with inverter?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Sep 2005
    thats what I wanna know... so im not the only one that's totaly confused by this... and in my bios, there are very limited options- with no option for resume on power loss
    Aug 2005
    Doncaster
    Sounds to me like ur a very lucky b****rd !!! People go to great lengths to get working what has just automatically started working for you
    Wish mine would do that!
    Dec 2005
    Ontario
    Did you ever figure out why your laptop was powering on by itself? Mine is doing the same thing.
    I too bought an el cheapo DC-DC converter off Ebay and whenever I switch my key on, the laptop fires up. Yes it is very convenient and no, I'm not complaining, however I'd love to know why!?
    When applying power from the OEM AC adapter, this does not happen. I'm slightly worried that the universal Ebay adapter is "spiking" on initial power up. Hopefully there is no long term damage caused by it. Sometime when I'm bored I might try to meter it and see.
    For the record I'm using an IBM ThinkPad T21 with a universal adapter model SC1220.
    May 2005
    Vienna, VA
    Weird ****. Mine is doing the same thing, too. I got a Dell 600m hooked up to a docking station. Mine doesn't have "auto resume on power loss" or whatever. Hopefully, it's not causing long-term damage, either.
    The thing is it just started doing this about 2 weeks ago. Before that, I had to push the relocated power button to turn it on.
    If anyone figures out why this happens, let us know.
    Newbie techyguru's Avatar
    Nov 2005
    Bloomington, MN
    You are just learning to channel your thoughts into the electronics you love.
    just kidding, and yes I know this is a dead thread but had to say it.
    Apr 2006
    CA
    If it is a cheap adapter then maybe it does a bad job at maintaining a constant voltage level. When you start the car the starter motor draws a lot of power and can drop the voltage a couple of volts. Maybe the adapter is not compensating for this and is over/under supplying voltage to the laptop. On desktops this situation (brownout) can cause the PC to reset. Maybe this is happening for the laptop. On a laptop when the AC adapter is unplugged the computer senses a lack of power and goes to battery. But what if this drop in voltage did not trigger the laptop into battery mode but does not provide enough power to keep the circuits on for the charger, clock, button sensor... maybe thatís the problem.
  1. Remote laptop startup
    By ambush in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2008, 03:28 AM
  2. Replies: 55
    Last Post: 08-27-2005, 10:40 PM
  3. Replies: 17
    Last Post: 08-03-2005, 06:12 PM
  4. Replies: 3
    Last Post: 08-20-2004, 09:42 AM
  5. system with removable laptop
    By latca in forum Newbie
    Last Post: 04-27-2004, 12:43 AM
