Results 1 to 5 of 5
Thread: laptop power supply
    Oct 2005
    laptop power supply
    I have an extra laptop power supply laying around and i was wondering if i could cut the plug end off and re-wire it in to my cars system to run my carpc? I would get a shutoff control to run in the middle of it. Would that work
    thanks
    chad
    gbh
    gbh is offline
    Constant Bitrate gbh's Avatar
    Oct 2005
    Massachusetts, USA
    It depends.
    Is it a dc to dc adapter?
    Is your carpc a laptop?
    Is your dc to dc adapter (if that is what you have) meant to power that laptop(if that is what you have)?
    Oct 2005
    re
    it is a normal laptop battery charger. as of now i do not even have a carpc but i am in the planning process and I am to the power supply part of my planning. My carpc will be based around the VIA EPIA M10000. now that you know this does it help anymore and would it be possible?
    thanks
    chad
    gbh
    gbh is offline
    Oct 2005
    Massachusetts, USA
    Quote Originally Posted by chadcj7
    thanks
    chad
    You are going to need to use something like the M1-ATX or Opus it will depend on the overall power needs of your design.
    Read this guide to power supplies:
    FAQ: Power Supplies Explained (Part 1)
    It should help!
    Best of Luck!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Laptop power supply is not appropriate for use with an Epia M10000. Most of them are 19 volts. Too much for the Epia plus they don't output the right types of power for the Epia.
    Want to:
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 06:31 AM
  2. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  3. REVIEW::220 Watt DC-DC Power Supply: DSATX
    By seabeggar69 in forum Power Supplies
    Last Post: 03-20-2006, 04:53 PM
  4. Casetronic C137 120watt power supply
    By Change in forum Power Supplies
    Last Post: 11-13-2005, 08:15 PM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 06:32 PM
