Results 1 to 6 of 6
Thread: Extending Laptop Display Wires?!?
    Nov 2005
    I've read through a few threads around the forum in which people had extended their Laptop wires to mount the display a few feet away from the unit... HOW?!
    I picked up a Fujitsu Lifebook B (built in 10.4" touchscreen) from ebay, worked great, nice laptop! But I can't for the life of me extend this harness! The wires are 32awg and won't even twist onto another wire without breaking loose!
    My best attempt so far has been with an IDE cable to the terminal that was at the end of the harness. Since the wires are already in "ribbon" form it was relatively easy to line them up to the "terminals" on the adapter, but I couldn't get them to stay in the adapter! The stock wires were soldered into it. The terminals on the adapter are literally the size of a pin, there is no way i could solder it without getting solder onto the adjacent pin. (Though I had considered using a toothpick and cold solder)
    Nov 2005
    ~ I will pay someone if they can do this! Its getting VERY frustating!
    FYI; this is a 14 wire/terminal adapter that slides into the motherboard... And I did try Molex.com, they said its not one of theirs so they can't do anything for me.
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    I would say don't attempt.. I'ms till trying to figure out how to fix mine after I tried extending the LCD wires..
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    Nov 2005
    Yeah well unfortunately I'm in the same boat as you, lol... Already cut 2 of them, couldn't fix them, so I took the adapter apart.
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    A search would help you. Or a quick look in the FAQs finds this: FAQ: Using a Laptop LCD as Your Car PC Screen
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    Nov 2005
    As I said; I read through the related threads (including that one), but thanks for uhh?
    Unfortunately noone mentions what tools and materials they use. I'm thinking they used a cold solder epoxy, as its the only way I can imagine getting such small contacts attatched.
    For anyone interested; This is what I mean by cold solder epoxy; http://www.web-tronics.com/2400.html
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. Using org. laptop display
    By NadavN in forum LCD/Display
    Last Post: 08-06-2005, 12:51 PM
  3. Laptop screen as main display unit.. possible??
    By edmonton_mr2 in forum Newbie
    Last Post: 12-03-2004, 12:15 AM
  4. laptop display solution
    By cruzc_99 in forum Off Topic
    Last Post: 07-03-2002, 10:44 AM
  5. display and laptop question
    By jstrain in forum General Hardware Discussion
    Last Post: 04-04-2000, 01:05 PM
