Results 1 to 10 of 12
Thread: P1900 + Dell Laptop and docking station
    Jan 2006
    I have been lurking here for several weeks as I have been considering building my own in-car computer. I finally was able to get all of the parts, and I installed everything into my car yesterday.
    I have run into one problem with my P1900 that has me stumped. I have spent quite a while searching previous posts here and have come up dry on my particular problem. I have posted a question to the carnetix forums, but I thought I might cross post it here, as these forums seem to have more activity. I thought hopefully someone out there would know the answer.
    The following is my post to the carnetix forums:
    I have it powering a dell docking station with the 20v primary rail. The Docking station requires a 90w output to run. Looking at the instruction manual, I see that the P1900 can do up to 6.32 amps. All i need is 20v at 4.5 amps so I know the P1900 should be able to do it. The problem is, when I hook up the P1900 to the docking station, i get an arror that it is only running at 70w (20v x 3.5 amps) and needs 4.5 amps. Is there any way I can force the P1900 to output 4.5 amps?
    If that isn't possible, the only other solution I could think of would be to wire up an auto adapter to the laptop that I know works. The only problem with that is it would take an input of 12v, and I already have a device on the 12v secondary rail. I am afraid if I hooked up the laptop to that rail, I would overload the P1900. Is there any way to get the primary rail to output at 12v also? I would prefer to not have to do it this way, but will if I have no other option.
    Oct 2005
    Im not sure if i can 100% answer this but,
    But i recall that there is a ajumper in the P1900 that tells the secondary output where to pull power. and the manula tells you that if you want 12 volts then you route the power from the primary rail back into the second regulator, not sure if this means you are splitting the power?
    What are you running off of the 12Voutput?
    May 2005
    Vienna, VA
    Why don't you just wire up the auto adapter directly to the car's power source. It should be able to take in fluctuating voltages. The laptop has internal battery so it will survive cranks as well. That's what I do for my laptop and it's been working fine. I'm using the Linds 90w adapter, BTW.
    Oct 2004
    NY
    I to use an opus 150 with my dell laptop & I use a lind adaptor to power the laptop itself... controlled by the opus, triggered through a relay....... the opus powers everything else,starts & shuts it down, but the lind powers the actual laptop...
    Nov 2003
    Marietta, GA
    So I'll post my response here too.
    Where are you getting this error? Does this appear in a diagnostic window on you laptop? Can you post a picture of the exact message so that I can interpret it? The reason I ask is, this information does not make sense. The P1900 will provide whatever current is demanded by the docking station, up to its maximum available 6.3 amps.
    You don't have to force the P1900 to output a certain current. It will supply whatever load is demanded (think of your laptop as a big resistor) up to 6.3 amps.
    This would not be a good idea. Your P1900 should work without having to add another adapter.
    I need to better understand your "error message" and where it comes from. Also, please tell us what model laptop do you have? Some Dell laptops have proprietary power connectors with a sensor that will not allow them to work with any power source that is not made by Dell.
    MikeH
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by MikeH
    I bet that's it. I think the power supplies that have a circular barrel with a wire in the very middle are the proprietary ones.
    Want to:
    Oct 2004
    NY
    I think that is only dependant on charging the battery, not actually powering the laptop.....
    Oct 2004
    NY
    that's one of the reasons I went with the lind adaptor in the first place.....
    otherwise multiple power supplies shouldn't be necissary...
    May 2005
    Vienna, VA
    My Dell laptop (600m) actually detects the power source coming in (if it's docked) and if it's under 90w (even if it's made by Dell), the lappy will put out that "error" message.
    I think in this situation, the laptop wrongly detects the rated power of the p1900 due to the proprietary connector as Bugbyte suggested.
    Oct 2004
    NY
    ah, so that's where that error message is coming from..... I guess the lind adaptor may be your best option afterall... I know they are made to emulate the correct dell ps & work perfect with a dell laptop....... they are pretty expensive though.....
    the lind doesn't need a regulated supply & you can run it straight off battery voltage.... a dc/dc power supply can still do startup shutdown, & power all other periferals, but there may be cheaper options such as using a sequencer & point source load supply(s)... the 3.3v will be wasted & there are cheaper 12v & 5v supplies for sure....
    I used an opus 150 just because I had it left over from my last install.... I don't think I would have went out & got it just for this .......
  1. Replies: 8
    Last Post: 01-24-2006, 11:43 PM
  2. IBM Thinkpad / Docking Station issues
    By ODYSSEY05 in forum General Hardware Discussion
    Last Post: 09-29-2005, 02:21 PM
  3. Replies: 2
    Last Post: 01-21-2005, 07:46 PM
  4. Laptop with docking station?
    By mpfjr in forum General Hardware Discussion
    Last Post: 08-24-2004, 05:29 PM
  5. docking station for laptop
    By skeurton in forum General Hardware Discussion
    Last Post: 04-27-2004, 05:27 PM
