For some people the good old soldering method will propably be easier way, for me this was quite simple...Originally Posted by NRGZ28
WRT54G v5 runs VxWorks's OS and has less memory than v4 or GL v1. I didn´t even bother to try if v5 could be used.Originally Posted by n0irsmurf
Ne, jotka haluavat, keksivät keinot. Ne, jotka eivät halua, keksivät selitykset.
*** http://www.powerdose.fi ***
Weekend Warrior: Toyota Supra Turbo MkIV ( http://one.2hell.com )
Daily Driver: Volvo V70 MkII T5
No I didn´t. Just fixed IP. Check your laptop WOL properties if you have already working router.Originally Posted by NickFury
It's been a while since I did this, but I'm pretty sure you have to put your own MAC address in there. The IP address is .255 which means it's broadcast to all the 192.168.1.xxx. Before I made this work with the router I used a little app on my PC that I downloaded to test the WOL of the laptop. I plugged a few parameters into a GUI and clicked a button and it sent the packets and woke up my laptop. Then I moved on to the router.Originally Posted by NickFury
I've got the laptop to come on through WOL, however, when I commit the command to 'startup' it is not working. How long are you guys leaving the router off to test this? I've left mine off for about 30 seconds and when I plug it back in, I get nothing. But when I telnet in and send the command, it works like a charm.
Did you save the command as told or just committed it?Originally Posted by NickFury
Wake on LAN is an extremely poor standard. Some laptops support it, others don't. If your just talking about waking up from standby, most will have some support for it, but they usually have to be activated in windows. If you goto the network card properties in device manager under the advanced tab, you should find wake up capabilities. It should be set. You may also have to set some property in the BIOS.
Additionally, many laptops can be woken up from hibernate or from a completely powered off state. This is very much hit or miss how well it works between laptops though. On my dell laptop, WOL works great if you don't remove power to the laptop when its off, if you remove and restore power, it wont remember to wake up with the lan packet. On the other hand, my fujitsu lifebook works incredibly well, it will actually draws power from the network cable to listen for WOL and work even if the laptop is not plugged into the wall.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
This is true. Easy way to tell how laptop behaves when power is disconnected is to just open network properties (Windows), unplug and replug power cord and see what happens. At least this was how I checked the support.Originally Posted by god_of_cpu
Ya, I would assume that it takes power to keep the lan card awake listening... I'm looking to keep minimal draw on my battery while in standby.
Good point. Next I´m going to try how long the battery will last (with my laptop) and if the laptop will still wake up when the battery is drained completely (in car the laptop will get DC power in startup) and if it still will remember to wake up.Originally Posted by dmcdlrn
