Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Here's how to bring a laptop out of standby
  1. #21
    Newbie nr000001's Avatar
    Jan 2006
    Finland
    Just tested the router/laptop setup in car. Laptop woke up from standby like charm. On my laptop the battery can hold up to 64 hours in standby mode. Works for me.
    Ne, jotka haluavat, keksivät keinot. Ne, jotka eivät halua, keksivät selitykset.
    *** http://www.powerdose.fi ***
    Weekend Warrior: Toyota Supra Turbo MkIV ( http://one.2hell.com )
    Daily Driver: Volvo V70 MkII T5
  2. #22
    Nov 2005
    Quote Originally Posted by nr000001
    This really works! I bought the new Linksys WRT54GL (cheaper than the WRT54G, at least here in Finland), upgraded the new aftermarket firmware (DD-WRT; works for L-version), made the config for WOL and added the code timeshifter wrote to the first post. No more laptop power button butchering.
    WRT54GL seems to be quite powerful router... I just may have to buy one for home use too.
    NOTE: I you are not familiar with routers and firmware upgrading, read carefully DD-WRT documentation. Using aftermarket firmware may cause void warranty.
    I just got my GL today. I flashed the firmware to the mini first (like the doc says) then to the standard firmware. I found where you do the WOL but there is no place to "input" code. I tried everything. Probably not using the best of laptops to try either... I hate my Sony Vaio, but I don't want to go pull my toshiba out of the car.
    Anyways. How did you set it up using that dd-wrt firmware? Or did I miss read and you did the other firmware? And if so maybe you can answer some other questions I have like, what you input for the boxes.
    Also, how are you guys hooking this up in your car? I'm guessing since it's just 12v, you hook it up to the battery, but I could be wrong.
    ::edit::
    I'm really confused... because I could have sworn that there was Wake on Lan or wake on ring or something for my Toshiba Satellite A45-S120 but in the BIOS.... I can't find anythign... Not one thing for this. And I thought there were, I even upgrade the BIOS and still nothing (actuallly looks the same so i don't know what the point was) But can someone help me out on that?
  3. #23
    Jan 2006
    Finland
    Quote Originally Posted by n0irsmurf
    ::edit::
    Quote Originally Posted by timeshifter
    ... click on Administration then Diagnostics then click the Run button. ...
    <- Here you should find place to write the startup command in DD-WRT.
    I just flashed the mini since the router is only a "start up switch".
    For power I use a simple DC-DC transformer (don´t lnow if this is the right term for the device).
    Don´t know about toshiba, but did you check your windows settings first? (assuming ypu are running windows).
  4. #24
    Nov 2005
    Thank you.. right before I checked this for the code again I found it.
    And when you say windows config.. where exactly, because I've checked the bios but in windows i'm not completely sure where.
    ::edit::
    Nevermind, found it, testing it on my Toshiba right now. Works fine on my Sony.
  5. #25
    Nov 2005
    Ok, so here's my dilemma. My sony works no problem... kinda cool actually. But it's a powerhouse and completely over kill for my car. It overheats frequently and I've been spending more money on my Toshiba, car adapter, etc. I found where the WOL setting was on my Toshiba, but the problem is that it doesn't supply power to it when the computer is in stand by. I"ve searched high and low, but can't find any possiblities.
    I wouldn't have a problem using the sony if it didn't need so much power, it drains pretty fast in standby or anything. And this Toshiba isn't any older than the sony, (actually newer if i remember right) And I can't believe that it doesn't support a great feature like wake on lan... but what ever. Maybe another idea?
  6. #26
    Jan 2006
    Finland
    Did you check your NIC settings in windows (Power management)? Is the "Allow this device to bring up the computer out of stand by." checked? Did you check that your NIC settings are same with AC and DC power?
  7. #27
    Nov 2005
    Well, neither of those options are in the power management... and I don't even see them on the vaio so i'm hoping i still have some luck. But I did see it on the nic settings, I remember that. But nothing of the same for the toshiba, I just went and downloaded the actual driver from intel's site, intel pro/100 ve, and it has a lot more options with it, and even a WOL option where it didn't before... and what is "wake on link"? there is that option with the toshiba drivers.
    It's such a nice router and I don't really want to send it back, but so far, it's looking like the case.
  8. #28
    May 2005
    Rochester, NH
    for now... in the cold it will not last as long, and depending on the type of battery, they really don't take constant cycling super well... I would worry that after a year the battery would last little to no time, but thats just my opinion on what I had seen with laptop batterys when I used to sell laptops.
  9. #29
    Feb 2006
    I got this working too with my laptop and a linksys wrt54g v3.1 router.
    But a couple of questions:
    1. Is it not possible to wake up laptop from hibernate with WOL in any way?
    2. Where in the router settings can you setup the router as a client ?
    3.(noob) If I use a relay with the ignition as a trigger, to power a touchscreen, laptop charger, and the router how do I split the power cords after the relay to power up everything?
  1. No Sound, Laptop wont boot.
    By tjp12100 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-27-2015, 05:06 PM
  2. why does my laptop turn on?
    By Efess in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-02-2007, 09:45 PM
  3. Bringing laptop out of Standby mode
    By timeshifter in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-13-2006, 11:18 AM
  4. Laptops, Standby and USB Power Idea
    By matthewtoney in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-17-2005, 11:38 PM
  5. Laptop for carputer project
    By airborne_cookie in forum Newbie
    Last Post: 05-31-2005, 11:23 AM
