There is no standard for any switch. The fact that there are 6 leads doesn't really tell us much. You will need to test all the wires against each other with the "continuity" setting of you Multimeter to determine which contacts are "close" or connected when the button is pressed.Originally Posted by hooraysimpsons
Then, just solder wires to those contacts (you will probably only need 2 wires on two contacts) and bring them out to a relay that you can control with the ignition or with another switch.
Now, are you sure that the screen switch will put the laptop into standby or hibernate and take it out when it is open??
Michael
LinkBack URL
About LinkBacks
