Results 1 to 4 of 4
Thread: Powering a Laptop
    Feb 2006
    Powering a Laptop
    Is there any way to wire an opus or equivalent dc-dc ps to a laptop, bypassing the brick?
    Thanks in advance.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by hugeness
    Thanks in advance.
    Probably not. It would depend on what voltage your computer needs. If you look at the brick, it should say what the "output" is. If it is 12 or 5 volts, then yes, you can. However, I have found that most computer require 16 volts or more. Although, I believe Carnetix has a unit that puts out 19 volts or so, that might work. You might want to consider a DC-DC Laptop adapter, they are not expensive. Then just ad a SDC.
    Let us know.
    Michael
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    opus 150W is an ATX psu so no.
    laptop dc-dc, carnetix P1900 yes. have a little and look at some examples and ideas - especially how to turn the laptop on. there are loads of threads about it.
    Feb 2006
    get a p1900 and ditch the opus. power your screen, computer, and usb hub all from the same psu with built in sdc. Run the internal ACPI jumper to your laptop power switch and you're in business.
  1. Inverter not powering laptop
    By noreason in forum Power Supplies
    Last Post: 02-12-2006, 03:52 AM
  2. Replies: 1
    Last Post: 02-03-2005, 10:32 PM
  3. Powering Laptop with the Car Battery
    By mintee in forum Power Supplies
    Last Post: 11-29-2004, 08:38 PM
  4. Powering up a laptop remotely
    By dmbrown73 in forum General Hardware Discussion
    Last Post: 03-07-2002, 01:25 PM
  5. Powering up a laptop remotely
    By dmbrown73 in forum Power Supplies
    Last Post: 03-07-2002, 08:40 AM
