Results 1 to 5 of 5
Thread: Laptop screen issue...
    banned - scammer 97GST's Avatar
    Mar 2006
    Tijeras, NM
    One of my laptops that I just got have a problem. A problem that is confusing me. About 1/3rd of the screen will remain white/blank, but sometimes faze in and out of what is supposed to go there and then go back to blank. But one time that I turned on the computer, the screen worked fine. And looked gorgeous. I looked over the mainboard of the laptop, fidn't find anything noticably wrong, what could this be? A wire? Screen? Internal Hardware? Or is this thing just a paper weight now?
    1998 Mitsubishi Eclipse GS-T
    ABIT NF-M2 nView | AMD Athlon64 FX62 Windsor | nVidia GeForce 6150 | Realtek ALC883 7.1DTS | Vista x64
    RF Power T162S | RF Power T162S | 2x RF Power T212D2 | RF Power T8004 | RF Power T20001bd | RF 3SIXTY.2
    Oct 2004
    NY
    ribbon cable or connections to/from the ribbon cable for the lcd....
    if the laptop has a lot of milage on it the ribbon cable is fragile & excessive opening & closing can actually damage the ribbon... check & reinsert connections both ends... if not a ribbon cable off ebay if avail may solve the problem, if not just chuck it out the nearest window
    Mar 2006
    Tijeras, NM
    I should be able to see visible damage to the cable right? So I could unsleeve it and inspect it thouroghly (sp)? Cause i've unpluged it and everything. When I unplug it, instead of half the screen being white, the entire screen goes white. I know the screen is fine because It just worked an hour ago. When I got the top, it came to me with this problem. But then out of the blue, as I had the top torn apart to fix the charging issue, the screen worked fine. Now its back to its old tricks.
    Oct 2004
    NY
    sometimes you can see the damage, but I've seen some that look fine, but don't work fine... I guess you may actually be able to ohm out the traces.... but if the connections are good it's likely a bad ribbon...
    Mar 2006
    Tijeras, NM
    what about signal interfearance? Half of my cable is steel braided which comes out to a ground wire thats supposed to ground the cable to the casing of the screen, and there are two hard round things around this cable... Does this stuff matter? or can I chop them all off?
  1. Xenarc Touch screen issue with SONY T-140 Laptop
    By riuster in forum LCD/Display
    Last Post: 07-22-2005, 10:52 AM
  2. Anyone interested in my Dell 15" Laptop Screen?
    By Sonicxtacy02 in forum Classified Archive
    Last Post: 02-02-2005, 02:20 PM
  3. HELP LAPTOP screen
    By daguju1der in forum LCD/Display
    Last Post: 07-25-2004, 06:47 AM
  4. LCD Laptop Screen Help??
    By slammedblazer09 in forum LCD/Display
    Last Post: 02-19-2004, 08:03 PM
  5. laptop screen model number
    By mp3z24 in forum LCD/Display
    Last Post: 05-27-2002, 09:00 AM
