Results 1 to 5 of 5
Thread: Power button won't work when laptop lid is closed
    Aug 2006
    Central PA
    I have my power button rigged up and working woooh . I noticed my problem the first time I took the laptop out to my car to test it. I closed the lid and tried to power on the laptop... nothing.
    I took the laptop back to my work area, opened up the lid and tried my power button again. VIOLA, it works. I couldn't figure out what was going on so I tried the first thing that I thought would cause the problem, that little hinge that hold the lid closed. After "removing" that I tried it again, still nothing.
    I looked the whole laptop over and I can't find anything that I can see that would keep the laptop from powering on when the lid is closed. Hopfully someone has had the same experience and can lend me a hand.
    Mar 2006
    Blog Entries
    1
    I just discovered the same problem today too. LOL. I just open up my case and unplugged the 2 prong wire harness that senses wether the case is open or closed. Lucky for me there was only two screws and one plastic piece that had to be removed to access it. Now it works great.
    FYI, my notebook is the HP 4420US.
    Aug 2006
    Central PA
    My laptop has one piece wireharness that goes into the motherboard and two wires (possibly like you suggested) that go way deeper into the motherboard. The screen doesn't work anyway. Are they harmless to just snip off?
    Mar 2006
    Blog Entries
    1
    If you know for sure that those 2 wires goes to your lid screen closure detection, then yeah.
    Aug 2006
    Central PA
    I just removed the whole screen, hacked off those two wires and everything still work so problem solved .
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. Power Button not working?
    By NoTicketsPlease in forum Newbie
    Last Post: 02-28-2006, 11:43 PM
  3. ciruitry and solder help for ibm laptop lid switch
    By hooraysimpsons in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-20-2006, 05:58 PM
  4. Replies: 47
    Last Post: 05-03-2005, 01:28 PM
