Results 1 to 4 of 4
Thread: Building a carputer from a broken laptop
    Oct 2006
    I have an inspiron 5100 that recently had a the whole motherboard go bad. I was wondering if it would be possible to buy a mp3car.com case and mini itx motherboard and use these old parts, such as the ram, the harddrive and everything else needed. Are these old parts compatible with this kind of motherboard and will they fit in one of these cases?
    P.S. I also know I would need to get a new power supply.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by dosh142 View Post
    The HD yes, the ram probably not. WHat else do you think you need??
    Michael
    Jun 2004
    Rochester
    RAM - No, most of the new motherboards use DDR DIMMs, your laptop uses DDR SO-DIMMs (smaller physical size, won't work)
    Processer - Probably, if you buy a P4 mini-itx board.
    HDD - Yes, with an adapter
    DVD/CDRW - Maybe, will need an adapter if it is possible
    Battery - No
    Screen - No
    Power Supply - No
    ** Denotes an "in car" post
    In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
    Constant Bitrate Vineet Singh's Avatar
    Jul 2003
    Naperville IL
    Dosh, check out this post I made regarding the Dell Inspiron 5150's (5100 is 99.9% similar with a different power connector).
    Inspiron 5150 Warranty reinstated for 1 year
    I have a contact at Dell, that could help you out, and get the board replaced for free (possibly). You have to PM me though to get the info, and promise never give out his info to the general public (I don't want him ****ed at me).
    Alternatively, you could call them multiple times until you get a helpful tech that will listen to your problem.
    It's only covered if you didn't spill or do anything like drop it to damage the board... they have power supply problems, charging problems and heating problems.
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
  1. Everything for a laptop based carputer
    By jbrown9709 in forum Classified Archive
    Last Post: 06-27-2005, 08:36 PM
  2. Replies: 15
    Last Post: 03-26-2005, 01:46 PM
  3. Laptop as a carputer. What do i need?
    By TommyTott in forum Newbie
    Last Post: 11-11-2004, 05:17 AM
