Results 1 to 10 of 16
Thread: Turning on laptop...this has been discussed
    Apr 2006
    I know there has been millions have threads on turning on a laptop, and I have probably read alot of them. I don't want to mess with wake on lan, wake on ring, I dont have UPS power on resume for my laptop, and I cant just solder on an external swith because the button manually presses down on a mechanism instead of an electical signal through a wire.
    The laptop is about 4 years old, it is a toshiba satellite A25-S207. What is the simplest method for me to turn of my laptop in the car? I am sick of getting out and pressing the button in my trunk every day. Please dont just tell me to . I just need some help, (BTW im only 16).
    Oct 2004
    NY
    Quote Originally Posted by black06stang View Post
    that mechanism HAS to connect to a switch that may be part of the mechanism, the computer has no way of knowing anything about mechanism's, all it can see is continuity between two points,those two points will be a ground reference & another that sees a ground pulse as an on signal request... you have to find these two points... any pictures??
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Like TC said. That mechanism is connected to wires. At some point, the computer, an electrical device, needs to know that the button was pushed. THat is the point which you have to solder to. Just like, your car, when you put the key in and turn the it, that is mechanical, but the car knows this is donw because WIRES CONNECT power.
    Pictures would be helpful, but they are probably no different then any other laptop.
    Of course, if you are unwilling to use WOL, WOR, etc.., and your laoptop is "mechanical" as you state, then you can't use the laptop. Get something else.
    Michael
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    I don't want to mess with this..
    I don't have that..
    I can't do something else..
    Don't tell me to search..
    I just need help..
    I recommend a long pole....but not to push the on/off button with!!! ;-)
    Oct 2004
    NY
    if you really can't mess with the switch (wimp), a cable like a gastank release could be rigged, (bicycle cables) or a small electrical solinoid could be rigged even, but cleanest is to just go to the board...
    Newbie 1bad2v's Avatar
    Sep 2006
    Hampton, VA
    take you laptop apart and just solder the damn wires on the frikin switch and wire to your car how you see fit. No need for mechanical this or that.
    Low Bitrate McFreak's Avatar
    Mar 2005
    McKinney, TX
    Bottom Docking Station
    I found the pin that presses the power button on the bottom docking station port. I doubt it is the same but it was just one pin and then a ground to the case to turn it on and off... I have a picture if it would help. Though mine is an IBM laptop.
    CarPC v2: Infiniti G35 Coupe 6MT, DW Housing, IBM R40, GPS, XM, StreetDeck
    Sep 2006
    got a question do the length of the cables matter... like will it lose signal after so far?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by darkdrake View Post
    Which cables? And yes, it does and it will.
    Michael
    Oct 2006
    Eastern Canada
    Yup, think of Ohm's law, V=IR
    The longer the cable, the more resistance. (R)
    Parts: [||||||||||]
    Build: [||||||||||]
    2001 Toyota Corolla CE 5spd.
    Laptop:
    Pentium 4-M 1.8 Ghz
    512mb RAM
    40GB
    SUPER 7" VGA w/ TC
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 06:31 AM
  2. Remote laptop startup
    By ambush in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2008, 02:28 AM
  3. Buying a laptop
    By Rocky388 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-13-2006, 01:13 PM
