To make things a bit clearer:
I had to mess around with this for a while before I got it right. I did it with two separate computers over the last week. I found the directions here to be very unclear (if not incorrect, in my case)
What I found worked for both of my computers was soldering two of the points AWAY from the brown spot(on the other side). Meaning: The solder point CANNOT be touching the push button switch in the center. If they are, the circuit will not go off.
