Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Where to solder on this switch?
    Apr 2006
    I am trying to connect 2 wire to the existing switch to make an external switch. When I try to solder to these points, the solder does not stick. I am pretty sure the points are made of solder that I am trying to solder the wires to. Does anyone know why they are not attaching, or what I can do to get them attached?
    Thanks (this is my first time soldering, though I practiced beforehand).
    Oct 2004
    NY
    jump any 2... either it'll start or it won't.... repeat as necissary..... when you find 2 that start it, you solder there
    there is no danger of hurting it...
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    make sure the connection points are clean, apply flux to the points of contact, put flux on the soldering iron, make sure you heat the solder the point you want soldered not the solder itself. good luck
    REBUILDING!!
    Oct 2004
    NY
    ps, the solder points are the little brown legs you drew...
    tin a wire tip, touch it to the leg, then heat just until the soldered tinned wire tip melt's & pull the iron away..... hold it still for a few seconds, then tug slightly to make sure it's a decent connection...
    Oct 2004
    NY
    flux can be ok, but I wouldn't use it here, everything should be clean aready, & you don't want to transfer much heat...
    Aug 2004
    yeah I was just suggesting the flux cause he said he was having problems getting it to stick
    REBUILDING!!
    Oct 2004
    NY
    I think he's not soldering in the right spot, the little brown legs he drew is where to solder, & you have to tin the tip of the wire first...,
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    DEFINATLY USE FLUX... without the solder wont stick unelss you get everything REALLY hot (including the target metal)... which can possilby melt any plastic touching that metal. The flux allows the solder to flow better at lower temperatures on the target metal. Put a bit of flux on both ends of the contacts then after touching the iron in the flux (to remeove any oxidation) dab the iron in the solder and then touch it to the piece. This is what is called tinnning it coats the metal with solder.
    Once both ends are tinned, place them together and just head it up with the iron. This will melt the solder together giving you a clean contact.
    Like stated before...but i thought i would clarify tinning and why flux helps.
    Brown 2010
    Oct 2004
    NY
    if the iron is hot enough, the tinned wire tip will liquify & also solder to the switch in like a second or 2... flux can be used, but isn't necissary at all...
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC - Alexandria, VA N/W Area - NOVA
    Quote Originally Posted by turbocad6 View Post
  1. help with micro switch
    By blackcar in forum Hardware Development
    Last Post: 05-21-2006, 12:50 PM
  2. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 11:48 PM
  3. Need help with X31 port replicator power switch
    By viguera in forum General Hardware Discussion
    Last Post: 06-22-2005, 12:12 PM
  4. Help needed on switch install for Inverter
    By eazyrog in forum Power Supplies
    Last Post: 07-24-2004, 07:42 AM
  5. Savage Switch Botton Group Buy via UK's Iconstyling.com....
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 11:51 AM
