Results 1 to 4 of 4
Thread: Can I plug an AMD XP 2000+ into a laptop?
    Variable Bitrate miwise's Avatar
    Sep 2006
    Will it damage anything if I try to plug my amd xp 2000+cpu (non-mobile) into my laptop motherboard with a duron 1100 mobile cpu? Its alright if it don't work, but will it damage anything if I test it? They are both Socket A CPUs. Thanks!
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
    Elsewhere
    Possibly.
    It's likely taht it will work, although there will be two possibl issues:
    1 - Heat dissipation. Teh AthlonXP will generate far more heat than the mobile Duron, and you're going to have to pull it out of the laptop casing somehow.
    2 - The laptop may not be able to identify the AthlonXP properly, meaning you'll have to set FSB & multiplier settings manually, either in the BIOS, through jumpers or using the pin mod.
    How about the Wiki?
    Sep 2006
    Well, I'm going to look into it. The main reason I want to try it is not to install into my car. I wanted to test the motherboard with a faster processor. If it works, I'll probably get a mobile version.
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    Sep 2006
    OK, I tried the athlon xp 2000+ in my computer and it registered as an amd athlon 1200 mobile, but it crashed windows xp. . .blue screen (maybe overheated?). The fan kicked into super turbo mode as the 2000 generated a lot more heat. I guess this means it will not handle any more than 1200 megahertz (obviously a limitation of the board), so here's my question: If I buy lets say a mobile amd athlon xp 2000+ cpu, do you think it will be stable under windows xp? Will it run cooler than the stock 1100 mhz cpu as the new one will in essence be running underclocked to 1200 mhz? Thanks! BTW, I think my old 1100 duron bit the dust. I don't know what happened, but the computer just turned off while I was on my way home. I'm thinking it overheated, but I don't know. It won't even boot with the 1100 in the socket. I had a 1000 duron mobile laying around so I plugged it in and it boots perfectly to that. The freedom skin for roadrunner even runs under less cpu load. I guess the old cpu was just bad?
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
  1. Can't install xp on my laptop HD
    By camiloteram in forum Operating System Optimization
    Last Post: 07-12-2006, 02:34 PM
  2. WTB: Socket A CPU XP 2000 and higher
    By CJ8501 in forum Classified Archive
    Last Post: 01-18-2006, 12:23 AM
  3. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 03:37 PM
  4. power options missing on xp laptop
    By hotponyshoes in forum Software & Software Development
    Last Post: 12-13-2004, 08:01 AM
  5. massive noise when i plug my laptop in
    By robr in forum Car Audio
    Last Post: 06-01-2004, 06:06 PM
