Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: I think my laptop is overheating
    Variable Bitrate miwise's Avatar
    Sep 2006
    I have an amd mobile cpu, a duron 1.0 and a duron 1.1. Both cpus are exhibiting the same behavior. The heatsink gets so hot it burns me to touch it, and then after about 30 or so minutes of running it turns itself off. It will not turn back on until I either swap the cpu or let it sit for a while. The fan cuts in and out, so I'm guessing the motherboard doesn't think that the cpu is overheating and thereby not cutting the fan on enough. Since it's a laptop, how can I get extra cooling to the cpu?
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
    Sep 2006
    UPDATE: So far, the thing is working well inside. I don't understand it. The only difference b/w the house and car is that the car uses an lcd monitor. (I had the touchscreen disconnected when I tested it)
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    Apr 2005
    Queens, New York
    The same thing happened with me and my Toshiba A75....The problem was that the heatsink and fan was extremely clogged with dust...I took apart the laptop and cleaned it all out and everything was good as new!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Constant Bitrate Grimoire's Avatar
    May 2006
    Fayetteville, NC
    Air is your friend. Where is the laptop? I mean, where exactly.
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    yeah, clean it out and it should work well,
    if you are too scared to open the entire thing up just blow compressed air through the vents, not too much though... the fans will break..
    your best bet is to take it apart and clean it though
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    Sep 2006
    Quote Originally Posted by Cheekz185 View Post
    I cleaned the heatsink out about a week ago, but thanks for the insight.
    Sep 2006
    Quote Originally Posted by Grimoire View Post
    The laptop is sitting in the extreme right hand side of the trunk. It sits where the cd changer once was. It is getting good air b/c there is nothing below the fan and it should be getting more air here than it does in the house. Its not covered at all. I even took the keyboard off to try and discipate some heat that way (that's how I know the heatsink gets pretty hot, both in the house and outside in the car). Its not hot outside, its about 50 degrees so it shouldn't have any problems in that regard. Any other thoughts? I'm starting to think its not that its overheating. It may be something electrical either with the PSU (carnetix p1900), with the touchscreen monitor, or the usb soundblaster. I don't know if these can make it turn off, though other than the power supply which doesn't give any fault codes or the monitor which i extended its length with a cd changer cable (the factory one in the car). Maybe it has something to do with it. I wish there were a way to check the heat of the cpu to log it to see if its overheating. I'll run it without the monitor and sound card when I get home to see what happens.
    Signed,
    Confused
    Sep 2006
    Quote Originally Posted by Redian View Post
    I've actually had the laptop open several times. I've even replaced the cpu in it (the reason I have 2 cpus is that the original motherboard got fried by a faulty power supply).
    Dec 2005
    if you can leave the cpu+heatsink exposed, put a low profile fan on the heat sink may be from another laptop. the fan can be powered off from usb port with a resistor to convert from 5v to 3v.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    How are you powering the system?
    Michael
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. why does my laptop turn on?
    By Efess in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-02-2007, 09:45 PM
  3. Powerbook g4 12" + other laptop parts (mainly from a D800)
    By sabre in forum Classified Archive
    Last Post: 07-24-2006, 11:12 AM
  4. Buying a laptop
    By Rocky388 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-13-2006, 02:13 PM
