Results 1 to 8 of 8
Thread: Laptop GPS integration: voice over audio possible?
    Newbie atomic punk's Avatar
    Nov 2005
    To play MP3's over my stereo, from my laptop, I know that I can use the laptop's headphone out to connect directly to my AUX IN of my head unit (or even the CD changer plug, with an adapter).
    But I listen to Sirius radio most of the time. And that uses the AUX IN.
    So, if I wanted to use the GPS that I'm buying for my laptop, is there any way to get the GPS voice to sound OVER the radio like an integrated stock system does? I'm guessing not and that I'd have to have the AUX function selected when the GPS is working, so I can't actually listen to Sirius and have the GPS audio on long trips.
    Anyone run into this problem before?
    Thanks...
    Mar 2006
    Colorado, but Canadian!
    Well most people go full integration. Meaning for sirius get the ALP1 tuner, and the sirius to usb, and plug that in the computer. The computer will mix with GPS and send it out to the amp or in your case the HU.
    You can only have 1 input at a time. So your computer must do all the work and feed your HU. Get sirius tuner for the laptop. GPS for the laptop, and if you want terrstrial radio, get the HQCT. Then you won't need the HU any more.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2005
    Hm. All good ideas, thanks...
    But I really don't want to replace my Sirius receiver (the Sportster replay with the 45 minute pause/Rw/FF feature is great, plus it was a gift to me).
    Idea: what if I hooked up the audio out of my Sirius unit to the Mic (line) IN of my laptop, and the laptop A/V out to the A/V in of my head unit? I wonder if that would work. I could leave the head unit on "AUX" all the time and have the Sirius or DVD or MP3 or GPS coming through theoretically at the same time (switch between sources at the laptop screen or leave the Sirius & GPS on all the time. The MS windows volume control would control the relative volumes of the two sources)
    Is there any reason why this would not work???
    Dec 2005
    just try it, it is a simple experiment and will not cost you anything.
    let us all know if it works and how you like it .
    Nov 2005
    Roger that.
    Mar 2006
    Quote Originally Posted by atomic punk View Post
    Yes it will work for sound assuming you have a program that takes the audio in and streams it to the wave channel for output and not just stores it to the disk.
    Also there will be no control over the unit from the laptop. So you will have volume control now on 3 devices (HU, laptop, Tuner) as well as buttons to control everything sprawled out everywhere.
    Not optimal in my opinion, but whatever work for you.
    Yes it should work though.
    Nov 2005
    No, it's certainly not optimal, but I want to make the most of the equipment that I already own.
    I was planning to use the laptop's volume control to only control the volume of the laptop devices (MP3/GPS/Sirius tuner) relative to each other. I would set it and forget it. The head unit would control the master volume of the system.
    Program for thet audio in? I'll have to look into that, it never ocurred to me. Thanks...
    Apr 2007
    you explained how you are hooking up the sirius but how are you hooking up the Gps audio?
    ok... my .02c
    when I plug my sirius sportster into the line in on my carputer, it plays over whatever I have the carputer doing. (unless i mute that line)
    I tried plugging the Sirius into the mic in line, but like he said, you have to have a program to play the mic input.
    another idea... how about trying a Y cable for the line in input? someone will probably tell me how wrong and stupid i am but hey... just another thought for ya.
  1. Laptop GPS vs. Magellan, TomTom, Navman....
    By BlackTahoe26s in forum GPS
    Last Post: 01-11-2007, 12:19 AM
  2. Replies: 0
    Last Post: 01-14-2005, 08:08 PM
  3. laptop, touchscreen, GPS, lotta fun!!
    By adidas445 in forum Newbie
    Last Post: 11-29-2004, 04:10 PM
  4. GPS voice guidance and music...
    By sounder in forum GPS
    Last Post: 09-15-2003, 05:39 AM
