Results 11 to 20 of 21
Thread: Trouble finding a barrel connector for laptop
  1. #11
    Low Bitrate hypnotiq's Avatar
    Aug 2005
    What if i use a the connector from my orginial power source that has a third pin, would it trick the laptop into thinking that i'm using the original charger?
  2. #12
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    why not just buy a used power supply for cheap on ebay??
  3. #13
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by hypnotiq View Post
    It's not a simple voltage divider like some, it actually has a chip in it the supply that talks to the laptop. What they say to each other, no one knows (or at least not google when I first researched it)
    First of all, you sure you have one of those supplies? I think you do, but not 100%.
  4. #14
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    Quote Originally Posted by shotgunefx View Post
    well now I feel like checking this thing out.
    I wonder if the pc can be powered by a simple 19v psu with the battery removed ? maybe some of the necessary communtication is to the battery.
  5. #15
    Aug 2005
    I was reading this post by bugbyte:
    P1900 + Dell Laptop and docking station
    and it describes my charger exactly. So i also believe that i do have one of those connectors.
    My originial question has never been answered though, if i cut off the end of my OEM dell charger would that work without a doubt with my p1900 since it will have the chip in it?
    Thanks for all the help guys, i'm sure theres a bunch of other people with teh same problem
  6. #16
    Apr 2005
    Boston, MA
    The cheap isn't in the tip, it's in the power brick, no power brick, no chip. No work.
    Maybe if you could extract the chip out somehow and get it to work being powered by the p1900, maybe something could happen, maybe not. I don't know if the chip just reports info or something or it may actually be part of the charging circuit, no idea as it's all proprietary so no datasheets, etc.
    Probably the most likely solution would be for someone with an oscilloscope try and figure out what's being communicated, and then making a dummy out of a PIC that says what it wants to hear.
  7. #17
    Apr 2005
    Boston, MA
    Another possibility might be to hack the BIOS to skip the check I suppose.
  8. #18
    Oct 2004
    NY
    first of all, the Lind is the only adapter that WILL let the battery charge.... I had a dell 700m with the large barrel connector... the Lind works 100%...
    since I swapped out the dell for a gateway that also needed 19v, but had a different plug, I cut the plug off of the lind.... it uses 3 wires of course, but it's weird.. it has like 2 different voltage feeds, & I think one has a ground level that is 5v above the other... I didn't spend a lot of time analyzing it, cause when the 2 outputs are summed, the end result is 19v, which suited my purpouse....
    I don't think there is any communication, just a weird voltage configuration.... either way, if charging the battery isn't important, then the p1900 will definitely do the job... otherwise get a lind adapter for your model & it'll charge 100%....
  9. #19
    Apr 2005
    Boston, MA
    Quote Originally Posted by turbocad6 View Post
    Maybe it was just that they (Lind) didn't work at first??? Could have sworn I read it at some point.
    Anyway, any reason to get a Lind instead of just use the PSU and a regular inverter? Certainly seems cheaper to get a regular inverter.
    Anyway, if you go the Lind route, make sure it's big enough (watts) for whatever you are going to do. A dock requires a bigger one (at least the Inspirion) and it dies at the BIOS with a power message. Funny, it won't boot with a dock if you are on battery, though if you remove the power after the BIOS post, it all runs fine on the battery.
    God I hate Dell.
  10. #20
    Aug 2005
    So how does the lind work? Do you plug into your cigerrete lighter? If so, how do you get the shutdown controller to work?
    Edit: I just googled it, damn its expensive
  1. Navilock gps trouble!
    By damoru2 in forum GPS
    Last Post: 07-30-2007, 03:39 PM
  2. Pandora w/ Xenarc 700TSV and Barrel Connector
    By froalskiner in forum General Hardware Discussion
    Last Post: 07-20-2006, 03:39 AM
  3. What size barrel plugs for Xenarc 730tsv and Audigy NX 2?
    By Mears in forum General Hardware Discussion
    Last Post: 08-29-2005, 06:26 PM
  4. Create an OBD Trouble Code?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-16-2005, 11:59 PM
  5. Need help finding a sub box ...
    By shakes in forum Car Audio
    Last Post: 05-12-2005, 01:58 PM
