Results 1 to 10 of 12
Thread: Laptop in Car - ADVICE REQUEST Please
    Feb 2007
    I need to use my laptop in car for GPS.
    what is the best way to keep the laptop in a car?
    I don't want to buy an expensive mount (I am a student) nor drill holes for a mount. But if I just keep it on the front seat, it has few drawbacks:
    1. Laptop gets HOT quicky
    2. Takes up space on front seat - or if a passenger is sitting, he would have to hold it
    3. I have to turn my head all the way to the right and down to look
    Any suggestions? I will be thankful!
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    You don't really have a whole lot of options if you want to use your laptop. It's gotta go somewhere and you've already eliminated pretty much anywhere it can go. A while ago I saw someone with one of the small Scion SUVs who made a some sort of mount that pretty much held the laptop vertically against the dash (like the HP laptop docks). I've seen some cheap laptop car mounts on ebay but they are cheap and are just made from metal tubing and some aren't all that sturdy.
    I would say your options are:
    1) fabricate some sort of mount similar to what you've already looked at to save some $$$
    2) Get a small LCD screen and then hide the laptop under the seat or something and just mount the lcd on the dash
    3) If all you want it for is navigation then get an older HP ipaq or other similar PDA. Can sometimes find a slightly older model (windows or palm) for not very much. I've got an old iPaq that runs iGuidance and it's exactly the same as running it on the computer, except for the smaller screen. And I've just got a cheap little a/c vent holder thing that holds the pda using an air vent and I can move it from car to car if needed.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Jan 2007
    My laptop is one of the toshiba models that is known for overheating. I still put it under my seat. If the overheating is something new your heatsink may be clogged. I have a 7 inch monitor molded into the dash where the factory GPS screen would normally be so everything looks factory. I also soldered a 2 wire momentary switch to the power button so that I dont have to search for the power switch everytime i turn it on.
    Constant Bitrate mwmcginn's Avatar
    Dec 2006
    St Louis
    The above is probably the way to go.
    Mike M
    2006 Accord VP Sedan
    My worklog
    http://www.mp3car.com/vbulletin/work...-dads-car.html
    FLAC Marvin Hlavac's Avatar
    May 2005
    More info:
    Low Bitrate perpetualjon's Avatar
    Mar 2007
    Southern California
    Same Idea but metal pipe instead of PVC. I was inspired by this guy who is selling his "kits" on eBay.
    My full write-up on the [H]ardforum. I actually like the grill design on Marvin Hlavac as it allows the laptop to breathe better.
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by perpetualjon View Post
    Just don't get into an accident without a seatbelt or with a passenger
    Mar 2007
    Southern California
    'yea, that thought has already come up. I have room for a passenger but they would get cut in two if we had a collision. I'm already planning on replacing the laptop with a touch screen that's closer to me and won't be in the way of the passenger as much...
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Marvin Hlavac View Post
    And never be caught short again!!
    Apr 2007
    I am about to reinstall an old ThinkPad in my '96 Buick Regal, using it for music only. For quick startup and shutdown, I use DOS as my OS and MPXPLAY to play my mp3s. I use the Superlock strips (similar to Velcro, but much stronger) from Radio Shack. The best way I found to mount it in my car is over the center console. Once it is installed. the strips are not visible, and the laptop doses not move.
  1. FS more car pc parts - complete laptop athlon XP-M 4 parts
    By fuctup in forum Classified Archive
    Last Post: 02-02-2006, 01:19 PM
  2. need some advice building a car PC!
    By dsmstunna in forum Newbie
    Last Post: 01-23-2006, 02:03 PM
  3. Installing car PC in 1996 Honda Civic
    By PredatorCoder in forum Newbie
    Last Post: 08-18-2005, 08:58 AM
