Results 1 to 8 of 8
Thread: Rollover on lcd, how to fix?
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    I have a lcd monitor for the back seat and it's hooked up to an alpine 9860 dvd player and when i turn them on sometimes the monitor's image will act like it rolling over really fast and i have to turn off my car and turn it back on to fix it. other times when i'm driving down the road it will get a little one that last about 1 second. I was wondering if a video amp would fix this problem? or is it something to do with the screen or dvd player? Thanks, Drew
    Mar 2006
    Iowa
    anyone have an idea what it could be?
    1998 Camaro Worklog Starting over, New setup for 2010
    Mar 2006
    Colorado, but Canadian!
    Does the entire image actually roll up so for instance at one time the top of the screen is like 1" from the bottom and rolls over that way, or is it more of a wave effect?
    If it is a roll, then it sounds like the refresh rate is off. You could try that first...
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2006
    Iowa
    it's more of a wave. it is just a lcd, not a vga
    Mar 2006
    Then that is signal interferance. Either from a weak signal which an amp would fix or interference from a big power wire running too close to a unshielded cable type thing.
    Mar 2006
    Iowa
    i was figuring that but would that be why when i turn the monitor and dvd player on it will do that right when it gets a signal from the dvd player? why doesn't it do it everytime?
    Mar 2006
    Quote Originally Posted by sporty_drew View Post
    I don't understand. Can you rephrase?
    Mar 2006
    Iowa
    The monitor is set to auto one. When i give the monitor and dvd power sometimes it will display the picture perfectly but other times it will roll over and over until i disconnect the power (turn off car)
  1. How do you fix alternator noise on an LCD?
    By adamis in forum General Hardware Discussion
    Last Post: 08-23-2003, 09:31 PM
