I got VGA
video on a Kenwood DDX 7015
tonight I got a Kenwood nav cable witch I promptly cut up
here's what I learned so far
blue = +5v
power up signal
gray = seems to be same as blue
purple = +5v nav turn on signal
orange & pink wires seem to be data they spike to .2 volts DC when the screen is touched I need to do some
testing with an O scope to be sure there are two gray sheilded cables inside the nav cable the small one has 2 wires in side
white = I think is audio left +
red = I think is audio right +
sheild = ground
the bigger shielded cable is the RGB signal cable
yellow = green
white = blue
red = red
green = Fh
shield = ground for all signals
compatable Fh = 60hz only
tested at 640x480 32 bit true color 60hz
