Page 11 of 22 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 213
Thread: 800x480 on intel 945GM/GMA950 - is it possible?
  1. #101
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Sorry, I didn't realize you had the 8" widescreen. This was for the 7" widescreen, so sorry, I don't know if this will work for you.
    PixelClock 38400 <-- this will give you 73Hz refresh. You can try playing around and to get close to 75Hz, but I didn't feel it was as stable as this number, which displays fine
    HorzActive 800
    HorzSync 32
    HorzSyncPulse 56
    HorzBorder 0
    HorzBlank 252
    HorzSize 25
    VertActive 480
    VertSync 3
    VertSyncPulse 7
    VertBorder 0
    VertBlank 20
    VertSize 16
    Again, this is for the 7" widescreen 800x480. These numbers are a combination of powerstrip's settings and some stuff I found on this site.
  2. #102
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    Quote Originally Posted by psyrex View Post
    Hey thanks! I will try these settings.
    But now I need to figure out how to apply these settings. Is it in powerstip or should I create a custom driver installation?
    What is the best way you recommend? Should I read the userguide.pdf that is in the intel IEGD driver?
    Thanks again.
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
  3. #103
    Jun 2005
    Oakland, CA
    You could also just use the reg file linked from the first post of this thread and edit it to use my numbers. What I meant was that I got my numbers from powerstrip and other places (horizontal was powerstrip, vertical was elsewhere), not that the numbers should be entered into powerstrip. Sorry for the confusion. If these numbers don't work for you, let me know, and I'll point out how I got my numbers from powerstrip, and maybe that can help you find yours.
  4. #104
    Nov 2006
    Sao Paulo, Brazil
    OK, I got the reg file and opened it in notepad. The registry keys dont exist in my machine, I know that the big {number} key changes for every card type, but in HKLM\System\CurrentControlSet\Control\Video\{...}\0000 I dont have other subkeys (such as ...\Config\1\Port\5\General, in fact nothing beyond the \0000).
    I searched the registry for the reg values named PixelClock, HorzActive, ... but not found anywhere in the registry... My card is intel 815 based, maybe its very different from the other model...
    \/ |_ /\ [)
    1995 Civic Sedan EX
  5. #105
    Jun 2005
    Oakland, CA
    I know it doesn't exist. The reg file creates it. After it's created, you can continue tweaking it by changing the numbers (remember it usually displays in hex) and then rebooting.
  6. #106
    Nov 2006
    Sao Paulo, Brazil
    OK I will try to import it. I will have to do it tomorrow, because I already left.
    I dont want to sound lazy, but can you post here (or PM) your registry key? (I mean, in regedit just highlight the big number key {xxxxx} and click export). I just want to compare your key with the other I downloaded and mine. What is that big number under { }s? Isnt it a card ID or something that would change for every card model? If it is card related, I just need to add the subkeys and values under my {number} key? Btw, what is your card model? Thanks again.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  7. #107
    Jun 2005
    Oakland, CA
    Sure, here you go. The big string is just an identifier. I use an onboard 855GME, and the GUID (long string) changes at every reinstall.
    BTW, remember to rename this file from .txt to a .reg to be able to change your registry automatically.
    Attached Files Attached Files
  8. #108
    Nov 2006
    Sao Paulo, Brazil
    Hi psyrex! I imported the reg file, rebooted and no effect. I edited the reg file to use my GUID, imported, rebooted and same thing.
    So, today I've formatted my CarPC , and before doing anything else, I installed the Intel EIGD 5.1 drivers, this time it installed without errors. Then, I've imported the reg file (edited using the new GUID key), rebooted and no luck still. I mean, screen is still set at 800x600.
    Am I missing some steps? If I go to display properties, advanced, list all modes, 800x480 is not listed. I have everything from 640x480 to 1600x1200 but no 800x480.
    Thanks!
    \/ |_ /\ [)
    1995 Civic Sedan EX
  9. #109
    Jun 2005
    Oakland, CA
    Hmm, that seems like it's not even reading the reg entries. From my experience, it did that when the wrong drivers were loaded. Can you check with the whole "Don't search, I'll choose the driver to install" thing?
    Also, you can try entering the numbers when creating the drivers. See post 9 (first page). It looks like that, but different numbers.
  10. #110
    Nov 2006
    Sao Paulo, Brazil
    Thumbs up It works!
    Hey! It works!!!
    What I did:
    1) Reinstall XP (not really necessary)
    2) Install Intel EIGD 5.1 driver (because of 815 chipset)
    3) DO NOT REBOOT after driver installation
    4) Open the psyrex .reg file and change the GUID to my GUID
    5) Import the .reg file (double click it)
    6) Reboot
    7) Windows started with the screen streched up (couldn't see the top of the windows). This is because psyrex .reg was for a 7" Lilliput, and mine is 8".
    8) Installed powerstrip
    9) Reboot
    10) Opened powerstrip "Advanced Timing Options" and clicked a few times on the Blue arrow (right "cross", bottom) and the screen started adjusting and it fixed on the right proportions. Here is the screenshot of the settings that worked ok:
    I have a onboard VGA with intel 815 chipset and using Lilliput 889GL-80NP/C/T (widescreen, 800x480).
    Thanks a lot psyrex for all the help and the reg file!
    Also thanks WiCKeD 5.9L who started this thread and also Merzbow for that post with the original reg file.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  1. FAQ REQUEST: CPU Ratings
    By dontpntpool in forum General Hardware Discussion
    Last Post: 03-18-2007, 04:39 PM
  2. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  3. 800x480 on Intel 845, some hope?
    By sama in forum LCD/Display
    Last Post: 03-10-2006, 03:25 AM
  4. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  5. Replies: 3
    Last Post: 10-22-2004, 12:09 AM
