Page 14 of 22 FirstFirst ... 45678910111213141516171819202122 LastLast
Results 131 to 140 of 213
Thread: 800x480 on intel 945GM/GMA950 - is it possible?
  1. #131
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    Thumbs down
    Somebody here had problem with hibernation?
    Using these drivers my machine wont hibernate, it displays a message about the intel driver preventing windows to hibernate.
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
  2. #132
    Dec 2005
    Sydney
    wohoo thanks hithere, worked perfect!
  3. #133
    May 2006
    MA
    ok, i'll throw my hat into the ring also. I have an intel 915g chipset and a lilliput 889gl widescreen. I was able to successfully use the drivers from post #25 on page 2, [Thank You Giuliano] however the image seemed too tall, although it did fit the viewable area. also the driver only allowed a 60hz refresh rate which makes the simpsons look choppy(a cardinal sin). the lilliput thought it was running at 640x480 per the on screen menu.
    it's so close, what do i need to tweak this?
    thanks
  4. #134
    Constant Bitrate kwchan's Avatar
    Dec 2006
    Singapore - Smallest country in Southeast Asia
    anyone manage to get 800x480 with the latest IEGD 7.0 works on XP?
    http://downloadcenter.intel.com/filt...4&submit=Go%21
  5. #135
    Apr 2007
    Quote Originally Posted by vladcarpc View Post
    Hey! It works!!!
    What I did:
    1) Reinstall XP (not really necessary)
    2) Install Intel EIGD 5.1 driver (because of 815 chipset)
    3) DO NOT REBOOT after driver installation
    4) Open the psyrex .reg file and change the GUID to my GUID
    5) Import the .reg file (double click it)
    6) Reboot
    7) Windows started with the screen streched up (couldn't see the top of the windows). This is because psyrex .reg was for a 7" Lilliput, and mine is 8".
    8) Installed powerstrip
    9) Reboot
    10) Opened powerstrip "Advanced Timing Options" and clicked a few times on the Blue arrow (right "cross", bottom) and the screen started adjusting and it fixed on the right proportions. Here is the screenshot of the settings that worked ok:
    I have a onboard VGA with intel 815 chipset and using Lilliput 889GL-80NP/C/T (widescreen, 800x480).
    Thanks a lot psyrex for all the help and the reg file!
    Also thanks WiCKeD 5.9L who started this thread and also Merzbow for that post with the original reg file.
    I just followed these instructions and the display manager in windows shows the resolution set at 800x480, but the screen is reporting 640x480 still. I am running an 810e on the 5.1 driver since they dropped it on later drivers.
    ideas appreciated! I feel like this is progressing a bit though, so I am optimistic
  6. #136
    Apr 2007
    i got it. I used the reg settings from post #12 on this thread Intel 865 custom drivers
    All I did was modify the long string as vlad described above and now the display settings report 800x480 and the monitor confirms that it's getting that input as well.
    Thanks guys!
  7. #137
    Dec 2006
    Quote Originally Posted by Giuliano View Post
    Folks,
    Here's a package that was built to cover 800x480 with Xenarc timings on the Analog VGA port, for all of these Intel chipsets:
    852GM
    852GME
    845GV
    855GME
    915GM
    915GV
    945G
    945GM
    Here is the package:
    http://moschini.org/ALL-VGA-800x480-Xenarc.zip (925k)
    Hi,
    I am using 855GME and 700IDT, i would like it to display at 800x480.
    I have tried your custom driver, registry trick and powerstripe...but i am still stuck at 800x600.
    BTW, there is a new IEGD 7 on intel website, possible to customise based on that?
    Pls advise.
    Nov 2006
    Sao Paulo, Brazil
    Thumbs down
    Test hbernation. In the end I went back to 800x480 with regular intel drivers, because hibernation stopped working (and that is important to me).
    \/ |_ /\ [)
    1995 Civic Sedan EX
  9. #139
    Dec 2006
    how do u manage to get 800x480 with regular intel driver? which method u used?
    thanks
  10. #140
    Nov 2006
    Sao Paulo, Brazil
    Thumbs down
    Quote Originally Posted by kwchan View Post
    thanks
    No, with regular drivers I had to stay with 800x600.
    \/ |_ /\ [)
    1995 Civic Sedan EX
  1. FAQ REQUEST: CPU Ratings
    By dontpntpool in forum General Hardware Discussion
    Last Post: 03-18-2007, 04:39 PM
  2. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  3. 800x480 on Intel 845, some hope?
    By sama in forum LCD/Display
    Last Post: 03-10-2006, 03:25 AM
  4. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  5. Replies: 3
    Last Post: 10-22-2004, 12:09 AM
