Page 3 of 22 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 213
Thread: 800x480 on intel 945GM/GMA950 - is it possible?
  1. #21
    Feb 2004
    Quote Originally Posted by rigg419 View Post
    I do in fact use VGA, you must be a mind reader!
    I can't wait to get home so I can try this. Do you have a paypal? I'd love to throw you a quid as a token of my thanks. Alternatively, I'm a decent graphic designer if you need something photoshopped
    Glad I could help..
  2. #22
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    Hey there Giuliano, i don't recon i could sweet talk you into a XP Pro driver for the Intel G965 using VGA and a 800x480 rez on a Xenarc 700tsv?
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
  3. #23
    Feb 2004
    Quote Originally Posted by Felix509 View Post
    Hey there Giuliano, i don't recon i could sweet talk you into a driver for the Intel G965 using VGA and a 800x480 rez for Xenarc 700tsv?
    Here you go:
    http://moschini.org/G963-G965-800x480-Xenarc.zip
    Analog VGA only, 800x480 Xenarc timings on G963 or G965 chipsets.
    Let me know how it works!
    Thanks,
    G
  4. #24
    Oct 2006
    Bear, DE, USA
    Giuliano,
    I'm getting the "not all components of the driver installed properly" error after I execute the executable. This is on a Dell Inspiron 6400 with Intel 945GM graphics chipset. I extract the file, then run the setup in the utilities folder, as specified....anything I may be missing?
  5. #25
    Feb 2004
    Folks,
    Here's a package that was built to cover 800x480 with Xenarc timings on the Analog VGA port, for all of these Intel chipsets:
    852GM
    852GME
    845GV
    855GME
    915GM
    915GV
    945G
    945GM
    Here is the package:
    http://moschini.org/ALL-VGA-800x480-Xenarc.zip (925k)
    NOTE:
    The above package may not work on laptops, or systems with LVDS LCD panels attached. Analog VGA ONLY!
    I will build a package for laptops / LVDS and Analog VGA combinations shortly.
    I should also note that these configuration settings are not fixed in stone.
    They can be changed any time, using the IEGDGUI utility in the Utilities folder.
  6. #26
    Feb 2004
    Quote Originally Posted by hithere View Post
    Giuliano,
    That's a laptop... the driver build package didn't account for the local LCD panel, which it needs to.
    I'll build another package with the settings for a local LCD panel on the LVDS port.
    http://moschini.org/945GM-LVDS-VGA-800x480-Xenarc.zip (925k)
    This should set up the configuration with local LVDS LCD panel at its defaults, and the analog VGA port at 800x480 Xenarc timings.
    The two displays are set up in Clone mode, so both displays will have the same image.
    You can change this or adjust settings using the IEGDGUI utility mentioned above.
    For best results, uninstall any previous driver packages from Add/Remove Control Panel first.
  7. #27
    Oct 2006
    Bear, DE, USA
    Quote Originally Posted by Giuliano View Post
    WOW that was fast. I'm so impressed by the level of generosity on these forums. I'll give the package a try shortly and get back to you on results.
    And, once again, thank you.
  8. #28
    Feb 2004
    Actually, it's quite easy..
    The Xenarc timings were the most difficult part, and once I got that decoded into a Device Timing Description (DTD) file, I can re-use it for different builds.
    For laptops, I'm defaulting to having both displays set in Clone mode, where they display the same content, but can have different resolutions.
    These settings may not be optimal, but you can change it using the IEGDGUI utility or the Advanced button on the video control panel.
  9. #29
    Feb 2004
    LVDS (Local LCD) and Analog VGA - Laptops
    Here's a build for local LVDS LCD panels (Laptop LCD) and Analog VGA, with Xenarc 800x480 timings.
    Chipsets:
    855GME
    915GM
    945GM
    Package:
    http://moschini.org/ALL-LVDS-VGA-800x480-Xenarc.zip
    All the other chipsets don't have LVDS ports on the chip - use this one instead for Analog VGA only:
  10. #30
    Oct 2006
    Bear, DE, USA
    Giuliano, please accept my apologies, but none of these seems to work. I'll try a few different things and get back to you. Sorry to be a PITA, I sure do appreciate your efforts,
  1. FAQ REQUEST: CPU Ratings
    By dontpntpool in forum General Hardware Discussion
    Last Post: 03-18-2007, 04:39 PM
  2. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  3. 800x480 on Intel 845, some hope?
    By sama in forum LCD/Display
    Last Post: 03-10-2006, 03:25 AM
  4. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  5. Replies: 3
    Last Post: 10-22-2004, 12:09 AM
