Still have 800x480 at 601Hz
The other resolutions seem to haer odd refresh rates now also..
I installed Irfanview, like i said, I had a minimal install, no Pbrush.exe
Here a couple pics to show what is happening.
Here's a trick for capturing displays:
Hitting the Printscreen button will capture an image of the entire screen, and copy it to the clipboard.
Hitting ALT+Printscreen will capture an image of the Active Window only, whatever you have active in the foreground.
Once you've captured the image, run Paintbrush (pbrush.exe), and you can paste it in as a new image. Save it as a Jpg, and you can post it here.
And I'm glad that it works (sortof).. I'll look at the numbers again, and verify the settings..
According to Xenarc, the monitor should display 61 Hz as the refresh.
It's possible that I have the refresh rate off by an order of magnitude..
The first two bytes, 96,96, are what control the refresh rate.
9696 Hex in Decimal is 38550, or what is supposed to be 38.55 Mhz.
Try this: Go into the registry, and change the first two bytes in DTD_1 to 0F 0F.
0F 0F = 3855.
Let us know, thanks.
Ours is the age that is proud of machines that think and suspicious of men who try to.
___________________________________
Current SYSTEM
AMD64X2 2.5
Xenarc
ZAPCO DSP-6
ARCAUDIO SE Amps
Rainbow Profi CS365 & Profi Vanadium 12"
Okay, the characters are just ASCII equivalents of the hex numbers.. doesn't matter.
I'm going to snag a Xenarc sometime later this week, and do some more testing on my own..
Also I have my LVDS cable, so I'm going to be testing 800 x 480 on that LCD as well.. but that's a different issue.
Thank you for all the time, Giuliano// I will keep plugging away with it...
Current SYSTEM
AMD64X2 2.5
Xenarc
ZAPCO DSP-6
ARCAUDIO SE Amps
One other thing to try is to change the C0 byte to 0C.. I may have had that backwards.
Time to get a new Video card.................
ATI or Nvidia chipset, what works with the Xenarc??
Current SYSTEM
AMD64X2 2.5
Xenarc
ZAPCO DSP-6
ARCAUDIO SE Amps
nvidia puts out 800X480 out of the box (the 6150 integrated chip does anyways)
very good, thanks, look around for that... may just get a low end nvidia video card..
Current SYSTEM
AMD64X2 2.5
Xenarc
ZAPCO DSP-6
ARCAUDIO SE Amps
the Intel G965 chip set just seems to not want to work at all. I honestly should have researched more before choosing this motherboard... If anyone had the G965(X300) chipset working with a 800x480 resolution, i would like to use the board I have already, it seems to be a huge hurdle though..
I am not technical enough to make it work so I need to move to something that will work, it will be holding up my install soon.(I want it Right, not scaled 800x600)
Laters
Current SYSTEM
AMD64X2 2.5
Xenarc
ZAPCO DSP-6
ARCAUDIO SE Amps
