Results 1 to 5 of 5
Thread: Lilliput TS problem
    Apr 2007
    Lilliput TS problem
    Well I've searched the forums but no one seems to have had this problem. I bought a Lilliput touchscreen and PC off of eBay. The screen when I plugged it in worked great. When I powered everything down and restarted it later the touchscreen had stopped working. So I reinstalled the drivers, unplugged and plugged back in the screen and still nothing. I've done everything I can think of to get the touchscreen going again, but so far no results. The screen as a monitor works, just the touch part that isn't working. Oh, also when I go to the add button on the touchkit utility it says it has scanned both com ports but found no device, but the drivers are there....I'm kinda a newbie to the whole touchscreen/car pc thing, so any help at all on my very frustrating problem would be very much appreciated.
    The screen I have looks just like this one only in black.
    http://store.mp3car.com/Lilliput_8_V..._p/mon-005.htm
    Elsewhere
    Moved to the LCD/Display forum.
    Are you using the latest drivers?
    What OS are you running?
    Are you wired through a USB hub?
    Details....
    How about the Wiki?
    Nov 2006
    Having the same problem as above, TS was working fine then all of a sudden dropped out. Now the device can't even be detected. The problem appears to be hardware related, possibly power (I have my screen powered directly through a 12v filter which is connected to the battery, so overloading my MTX isn't the cause). Has anyone managed to solve this dilema??
    Sep 2006
    Phoenix Az
    It happened to me before, i think the problem is that connector that contains a lot of pins, try to play with it couple of times. I had problem when coming out of hibernation.
    Nov 2006
    When you say 'the connector', I'm assuming you mean the VGA cable ??? Did you find a permanent solution to the problem then??
  1. Lilliput TS problem.
    By FunkDaMonkMan in forum LCD/Display
    Last Post: 12-15-2006, 06:15 PM
  2. Replies: 7
    Last Post: 04-18-2005, 01:41 PM
  3. Lilliput Touchscreen problem
    By DookieGraphics in forum LCD/Display
    Last Post: 03-24-2005, 03:33 AM
  4. Replies: 0
    Last Post: 06-15-2004, 12:01 AM
