Results 1 to 6 of 6
Thread: cigi hijack
    Low Bitrate rudels's Avatar
    Mar 2007
    South Africa
    cigi hijack
    hi all... im doing a dash install and was wondering what would be the best way to power my screen? can i hijack my cigi lighter power? if i need more wires between the cigi lighter and my screen what wire must i use? is the a certain type or thickness wire that i need to get? sorry about all the questions im sort of new to this...
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    You should power it from the PSU's 12V rail or get a 12V regulator and power it from. 16GA or 18GA is good enough for serveral feet.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Mar 2007
    South Africa
    Quote Originally Posted by MatrixPC View Post
    thanx for the reply but the problem is that i dont have a carpc installed... yet... iv got a dvd front loader where behind my dash would i find a permanent 12v wire?
    Jan 2007
    New Jersey
    Hey I basically have the same question. Would 16GA speaker wire be good enough for this or would I need to get power wire?
    May 2007
    ok thatīs not so cool ?
    Are 16 GA good enough ?
    Greets v1nc
    Mar 2006
    Colorado, but Canadian!
    The screen draws about an amp. maybe a bit more. So any wire that has bout the same amount of copper as what is on the cig lighter adapter cord, will work.
    I personally think the best way to do it other than to your psu since you cant do that, is to just chop off the end of the cig lighter adapter, and wire those to your car's +12 and chassis. Now this will only work if there is an "egg" or a little black box thing on the cord that regulates the voltage, or if the screen has a range for the voltage input on the back of it.
    If your monitor must have +12v not 6v-14v and there is no egg, then the regulator is inside the plug part. In that case go to ratshack and get the $10 converter from cig lighter to bare wire. Connect, glue, tape up so no shorts.
    Then grab +12v from the battery, and ground to a good spot. The factory radio grounding spot should be sufficient
    1.9in x 2.9in -- 47mm x 73mm
  1. Annoucing iKarr
    By jdkarr01 in forum MacCar
    Last Post: 05-14-2009, 09:12 PM
  2. GPS software? Newbie help
    By dhantiflag in forum GPS
    Last Post: 04-26-2007, 07:15 AM
