DIY: Built a heater for my LCD
Well, I have a K301, and I am a bit dissapointed that my $400 screen does not operate in the cold (has a protection circuit). I have been trying to locate the sensor which senses the temperature, but so far, no luck.
I randomly stumbed across a page where the guy built a "dew heater" for his telescope using some resistors, and that gave me a thought. Why not use a bunch of resistors to make a heater for my LCD. So thats what I did. Here are some pics:
http://img373.imageshack.us/img373/2612/img8072re0.jpg
http://img373.imageshack.us/img373/7747/img8071wh8.jpg
I took some resistors from some old broken circuit boards and stuck them onto the bottom plate of my K301 (of course taking into account how to wire them properly). This system of resistors will dissipate 25 watts of power at 14 volts. I am hoping this will work for the winter time, but I am not sure. What do you guys think? Is 25 watts enough? Keep in mind that this system relies mostly on convection to heat up the entire unit. I tried to fit a fan with a system of ducts, but that was just too difficult.
Does anyone know how hot a resistor may get? I am using some standard resistors, ceramic, and wire wound (these get hot). I am just hoping my tape wont melt. I also have some silicone (used for windows, doors, moldings...), do you think I should use that to glue on my resistors instead of tape?
Advice or comments are welcome.
this is the first I come here
