You have to make a call on this one yourself.
Normally, I would do like this.
- If I'll plug the TS and other devices to the hub up front, I will run a vga and usb.
- If there is no other usb to be used up front, run a mini din
Which is a better option? 9 pn mini din extension from your trunk to front of the car to connect the lilliput LCD or using two seperate extension cables, one USB and one VGA. Any information will be helpful.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Thanks. I think I will use a usb and vga cable, cause i will have a cd drive in my glove box.
