Results 1 to 10 of 11
Thread: just got the 629 today and
    Aug 2006
    Michigan
    I finally have my Liliput 629..wondering how big the actual bare screen is when i crack it open. Like the mothboard and such. looks like i only have 4" to work with in height. ehh Thanks
    M10000 mobo, low profile 512mb ram, 2.5" 120gb hdd, 80watt power supply
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    there will probably be another quarter inch on top.. half inch on side.. but the visible screen is what u see is what u get
    Live mp3Car Facebook Chat
    Aug 2006
    Michigan
    yeah i know the screen wont be bigger...but im really close on fitting. when i cut the bezel, can i eliminate the buttons? that would give me a perfect amount of room if i can get rid of that much. Thanks!
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Sonicxtacy02 View Post
    plus like 1/8" on all side for the lcd's casing (not screens casing but the metal/plastic around actual visible lcd) and the edge of the screen with no picture.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2006
    Quote Originally Posted by Transamsfast View Post
    You didnt search at all...
    Yes the buttons can go away. YOull just need to either relocate the button panel, or take it off completely and use the auto-on hack, but no buttons means no hardware screen adjustments
    Aug 2006
    Michigan
    i did my research but when i made the computer i was going to get a new car. But i kept mine and tryed the best i could to do it. I think i will be able to. So you say the motherboard only extends like a 1/8" out from screen itself? and are the buttons on like a ribbon cable or actually wires?
    Mar 2006
    No what I said was the actual screen that you need to squeeze in wherever is going to be about 3mm on every side bigger than what you see now unopened.
    The motherboard is like sonic said. Mine was a hong kong version and was pretty much to the walls of the casing. Everything is all ribbon. The ZIF ribbon stuff. Except for the short backlight inverter wires, those are heavy guage wires.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If you put the bare lcd panel on an ISO double DIN, you should have about 1/2" on both side and 1/8 or 3/16" on top and bottom. That is the measurement base on the 2K Accord double DIN. I'll try to post some pic later so you can get better idea
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Aug 2006
    Michigan
    Would you happen to have a picture of one cracked open? That would help a lot. Thanks
    Aug 2006
    Michigan
    Quote Originally Posted by MatrixPC View Post
    I wish i had double DIN but pontiac's arnt. They are like 1.5 DIN
  1. Today is a double shot for me
    By sporty_drew in forum Off Topic
    Last Post: 04-08-2007, 08:36 PM
  2. lilliput 619 is reflective, 629 has antiglare?
    By kbyrd in forum LCD/Display
    Last Post: 06-23-2006, 08:44 AM
  3. Lilliput 629 screen not clear - help
    By gdawg in forum LCD/Display
    Last Post: 09-28-2005, 09:34 AM
  4. Just got my Lilliput today from MP3CAR.COM store
    By Sid3ways S13 in forum LCD/Display
    Last Post: 03-12-2005, 07:02 PM
