Results 1 to 5 of 5
Thread: Will this Inverter work for my LCD?
    Jul 2002
    Washington
    Question Will this Inverter work for my LCD?
    would this inverter thing work for inverting the backlight on my lcd so that the text was lit and the background is black:
    http://www.allelectronics.com/cgi-bi...V-8&type=store
    here is the lcd i have:
    http://www.allelectronics.com/cgi-bi...-74&type=store
    Anything worth doing, is worth doing right.
    http://www.mp3car.com/vbulletin/showthread.php?s=&threadid=15017
    Apr 2002
    South Coast, UK
    Your backlight is LED, it doesnt need any invertor, just a power connection to the correct pins. You need invertors for EL and Flourecent backlights, normally used in large flat panel displays, not text displays.
    (=========-) 99% complete
    AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
    All jammed in external CDROM drive case.
    Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
    Jul 2002
    Washington
    OH! all i have to do to get my lcd to display the letters lit with the background black is change a couple pin connections... TELL ME MORE.... please..... That would be soooo cool
    Apr 2002
    South Coast, UK
    No, to get it to be backlit you need to connect it up. To get the background black and the characters illuminated if its not like that already you need to change the polarisation of the light. This is done by using polarised film, available from some camera specialists. Its not cheap, and you ned to remove the existing film. Do a search, this has been discussed a couple of times in relation to Nokia mobile phones.
    Apr 2002
    South Coast, UK
    reversed lcd
    LOL, Ive just realised what you were thinking when you saw invertor? You wanted to use that device to invert the display! Invertors are used to create an AC drive voltage for FL and EL lights, they cant reverse anything.
    See the above thread about peeps reversing their displays.
