Results 1 to 5 of 5
Thread: 800x600 display too small
    Low Bitrate Super_dave's Avatar
    Sep 2006
    Does anyone see this as a problem the display in 800x600 is too small the read or even make out icons , is there a way to drop the resolution so window is readable ? on a Lilliput EBY-701 / 629
    Mar 2007
    640x480 works nicely on my 701.
    if 640x480 is not listed in your settings options, go to
    display properties > Settings> Advanced> Adapter> List All Modes
    Then select 640x480, True Color (32bit). Make sure you select the correct Hertz or your screen will go blank on you. For me 60 Hertz works fine.
    This will make your windows a lot easier to read. However, if you are running any software that won't fit a 640x480 window, you can use a program called rezchanger that will allow it to change the screensize when you launch the software, and return to the previous screen size when you close it.. Similar to what road runner does..
    Sep 2006
    Quote Originally Posted by ironfinger View Post
    Mmmmmmmm thank you master Ironfinger , your kungfoo is great Mmmmmmmmmm
    Mar 2006
    Colorado, but Canadian!
    THe problem with changing the actual resolution that way is that everything becomes big.
    So for instance S&T2006 wont display correctly on anything less than 800x600.
    Another way to do it, is under Display Properties-->Appearance, to change the icon size and everything to bigger numbers. Works great, and you get to keep the big resolution for programs that need it.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2007
    the above method works as well, however I still find things to be too small.
    That's why I recommended using a software called rezchanger. It will customize your screen settings to the appropriate size for applications that do not work in 640x480.
  1. 800x600 stopped working! Help Please! Ex-Audio TS LCD
    By 2k1Toaster in forum LCD/Display
    Last Post: 11-23-2009, 10:53 PM
  2. Small dot matrix display
    By david69leonard in forum LCD/Display
    Last Post: 01-31-2007, 03:02 PM
  3. 800x600 wont display right on my xenarc
    By nappyjim in forum LCD/Display
    Last Post: 01-23-2005, 03:59 PM
