Results 1 to 6 of 6
Thread: Wire Xenarc to radio 12 v ?
    Newbie vrslider's Avatar
    Feb 2007
    Hi Guys, I almost have my puter ready for implementation, i just have one question,
    can i use the 12 v and GND from the radio ( BMW E46) to power the Xenarc ?
    Many thanks for all reply's !
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    You could, but I don't know how "clean" that source is and it's effect on screen longevity.
    Recommend you read up on powering up your screen off your carPC's PSU.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by vrslider View Post
    Quote Originally Posted by Sal R. View Post
    Well the Xenarc actually has internal voltage regulation while the Lilliputs do not.
    And the screen doesnt draw that much, so stock wiring for only the screen is fine. If you have a lilliput though, you need a source of clean +12v, which then Sal is correct, get it from the PSU.
    1.9in x 2.9in -- 47mm x 73mm
    Feb 2007
    Yes its only for the xenarc..is it wise to connect it to the constant 12 v or the IGN 12 volt ?
    Mar 2006
    The IGN is only a trigger wire. Not meant to handle any current whatsoever. Constant +12v, and if you want you can use a relay triggered off of the IGN, but the Xenarcs have an auto-on feature, so it shouldnt matter.
    Feb 2007
    kewl ! i knew i bought the right screen !
  1. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 11:10 AM
  2. Stock Radio won't kick on?
    By IntellaWorks in forum Car Audio
    Last Post: 11-03-2005, 01:36 PM
  3. FS: molded xenarc VW radio cage
    By dyeinbreed in forum Classified Archive
    Last Post: 05-14-2005, 08:07 PM
  4. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  5. How should I extend the VGA wire (Xenarc LCD)
    By SpeedFreak03 in forum LCD/Display
    Last Post: 06-16-2004, 11:37 PM
