I wouldnt sand, I would dremel. YOu will be sanding for a long long time.
And yes everyone who wants an OEM install has to. Either the screen or the dash.
Hey guys, if I get an EBY701 I will need to sand down the top and bottom of the outer case. Can this be done safely? If so, what tools would you recommend?
Erock
1.9in x 2.9in -- 47mm x 73mm
I've got one apart right now. you've got around an 1/8th of an inch you can take off of the top and/or the bottom until you get into the screen. And ditto on the dremel.
