Results 1 to 10 of 14
Thread: [SOLVED] Lilliput 629, power but no image
    Newbie RichIbizaSport's Avatar
    May 2007
    Hull, UK
    Hi guys. Before we start ive searched the forums for an age and still not come up with an answer
    Ive just purchased a lilliput from a guy i know on another forum, it was working when he sent it, with pictures to prove.
    Ive tried both a the cigarette lighter and the mains supply. Ive tried it connected to my laptop, pc, ps2 and dvd player.
    It powers up fine, the power LED will be red when in stand by. I can turn the unit on by pressing power on the remote or the button on the control board. It will turn green when powered. I can then press any button on the control board and all the remaining green LED's will light up for 10 seconds. But absolutely nothing comes on the screen. Ive checked im getting power to the screen with a multimeter, im getting 0.2V AC via the power connector (2 wires). Ive checked the ribbon cables and all looks normal.
    Any help would be greatly appreciated!
    thanks
    May 2007
    Hull, UK
    If the ribbon cable connected to the screen is disconnected, should i still get a message on screen saying there no input or something? Or will the monitor be completely switched off if the ribbon cable isnt connected?
    May 2007
    Hull, UK
    Quick update:
    This is where the "high voltage" wire connect to the LCD, pressumably for the backlight?
    Ive found the manufacturing page for the LCD:
    http://www.hitachi-displays.com/en/c...353_18541.html
    It says that the supply voltage should be 3.3V
    Surely less than 0.3V isnt enough? What could this mean?
    Jan 2007
    Szeged, Hungary
    Re-connect that ribbon cable. The display is dead without it.
    Make a high contrast picture (eg. moving black box on white screen) and try to observe from different directions in sunlight or by a lamp.
    If you can see a very dim, but obviously visible picture, the display is OK.
    Backlight is totally independent.
    The backlight voltage you try to measure is approx. 600V, but high frequency, so I am not sure it is measurable by a multimeter...do not touch the ends.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by RichIbizaSport View Post
    Quick update:
    That is for the backlight and more likely it went south.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    May 2007
    Hull, UK
    Well, i managed to find the problem. A night with the trusty multimeter and i found a nano fuse that was blown (no visible damage). I temporarily bridged the fuse with the thinnest wire i could find to see if it worked and it did. So ive bought the fuse from america, should be on its way now!
    I have no idea how/why its blown as i havent connected it up with the wrong polarity nor have i used a wall adaptor with too many volts! :S
    Yeah! :
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    I just ordered some fuses as well. How do you remove the old fuse nicely? Do I desolder it?
    May 2007
    Hull, UK
    My fuses arrived yesterday, and all went well.
    MegaloRESE15" - Yes, you will have to desolder the old one. Its fairly easy with a steady hand and a small soldering tip. Melt the solder at one end and lift it up slightly with a pair of tweezers, then melt the other end and lift with tweezers once more and it should come straight off
    Jul 2007
    Norway
    Quick update:
    Think the problem is that you're measuring AC voltage, not DC as you should :P
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    If you connect your multimeter to a DC source, it will have the same reading no matter if its on the AC or DC setting (for my multimeter anyways). I think the AC setting simply makes the input voltage go through a diode rectifier so that the AC voltage is converted to a DC voltage which is then measured.
  1. Lilliput TC1000 12V Power Cable
    By Paul75 in forum Power Supplies
    Last Post: 06-14-2008, 06:07 AM
  2. Replies: 6
    Last Post: 06-25-2006, 12:18 AM
  3. lilliput 619 is reflective, 629 has antiglare?
    By kbyrd in forum LCD/Display
    Last Post: 06-23-2006, 08:44 AM
  4. for sale - Lilliput 629 Touchscreen $200
    By my350z in forum Classified Archive
    Last Post: 10-31-2005, 11:16 AM
  5. Lilliput 7" Black LCD but Power on VGA controller
    By zherlock in forum LCD/Display
    Last Post: 10-09-2005, 02:14 PM
