Results 1 to 10 of 10
Thread: Lilliput In-Dash Gears
    May 2005
    Toronto, ON
    Bah...it had to happen. My 7" Lilliput In dash was going strong for almost 2 years now. Today, I hit a bump in the road, and my screen came crashing down. It seems like the plastic gears stripped/cracked or something. It will slide in and out, but will not tilt up properly. Did anyone find a source for replacement parts? I'm thinking of taking it apart to see how badly it's damaged, but I'm not too sure how complex it is.
    Oct 2006
    I think Mickey21 at Austinmodders.com used a RadioShack ZipZap gear as a replacement for his at our last meeting. It wasn't drop in; as I recall - he spent quite a bit of time getting it to fit onto the gear motor once he got to the motor.
    May 2005
    Toronto, ON
    I shoot him a PM. Thanks.
    xsi
    xsi is offline
    Jun 2007
    I have the same problem, so please if you have any news please post it here.
    Low Bitrate erricson_nguyen's Avatar
    Feb 2007
    LA ca
    gears
    my also broke i've found online retailer , but dont know exactly bcuz the original was missin' couldnt find it, if you still have your broken 1 if you know how to use caliper measure it let me know and others as well then find it here
    http://sdp-si.com/eStore/Direct.asp?GroupID=207
    May 2005
    Toronto, ON
    I sourced some replacement gears. I'm so happy my screen works again.
    I have a few extras, so PM me if you need one.
    May 2006
    Where did you get them from mate? There are a few of us here in Aus with the same problem.
    May 2005
    Toronto, ON
    Got it from Lilliput direct.
    Mar 2006
    Direct from Lilliput?
    I have a Lilliput GL701NP and I am having the same problem. It will slide out, but not lift up anymore. Where can I get a replacement lift-up gear for this unit. I saw where someone said directly from Lilliput, but I can't find anything that doesn't involve calling China. ANY help would be greatly appreciated, I'm desperately missing my rig.
    Thanks,
    Constant Bitrate jac1502's Avatar
    Jan 2006
    I need a gear to any chance of buying one?
  1. Replies: 11
    Last Post: 10-10-2005, 10:05 PM
  2. Landrover Defender in dash Lilliput fitting
    By rustyboxx in forum Newbie
    Last Post: 02-08-2005, 10:14 AM
  3. Lilliput In Dash conversion question
    By patrol in forum LCD/Display
    Last Post: 09-12-2004, 08:01 AM
  4. FS Lilliput 7" faceplate fabbed into Saturn ION dash
    By brandon in forum Classified Archive
    Last Post: 08-24-2004, 10:51 PM
  5. Help !!, Lilliput In Dash Convert gone wrong
    By markie in forum LCD/Display
    Last Post: 04-27-2004, 05:35 PM
