That's not the problem.
The problem is in a switch on the main boar with the inscription "K1".
Check it if is not broken. Mine was.
I took apart my in dash screen this weekend, hoping to fix the gear that is broken for tilting up and down. However, one of the sensors is out of alignment.
Does anyone know how to set this sensor? It looks like this is used to check when the screen is all the way up and down. I don't think it's at the proper position. It was moved when I took apart the screen.
Is it a potentimeter of some sort?
I think that switch just detects whether the screen is fully extended or not. As far as I can tell, the switch is working ok because it stops when it's fully extended.
Where'd you find a switch like that?
I didn't.
I'm still searching for a new one.
And a gear too.
