bump
Hello again,
Just a quick one,
I am planning on running 3 touch screen lilliputs, mirroring the same image, using a powered VGA splitter and a Mac Mini as the source.
The question is, will the touch screens on all three screens work, (as one mouse I guess) if all usb's are plugged into the M.Mini via a usb hub?
That is how I would like it to work as well!
Thanks in advance!
bump
Yes it will but you have to calibrated all three screen.
No you can have as many screens connected at the same time, but only 1 mouse in windows. So they will all be the same mouse, but with the same image that doesnt matter.
By calibrate he means that when you calibrate or setup the touch presses to screen coordinates, you will need to do that for all screens.
1.9in x 2.9in -- 47mm x 73mm
ah right, thats fine, i'll only have one source, the passengers can fight for control!
Cheers guys!
