Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Did I kill my Lilli?
  1. #11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by 2k1Toaster View Post
    (Enforcer)
    But the regulator I was referring to was the onboard regulator. Probably 5v or 3.3v. It should be in a TO-220 package close to the power jack.
    looking at\one of the two I have in front of me there is a chip with B1203 written on it, looks like a very small 7805
    Quote Originally Posted by Skipjacks View Post
    I should be able to get that in any electronics store I imagine?
    I had to get mine online
    That'd be a pain in the butt. The power supply and inverter and all that business is in the trunk. The last thing in the world I want to do is run another wire under the carpet up to the dash. That was a royal pain the first time.
    I will gladly accept links to online stores that sell regulators though...
    Will be UK ones if I can find where I got mine.
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Enforcer View Post
    The B1203 is just a high-current transistor. It doesn't regulate voltage, but there should be a chip for regulation somewhere.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    Well let's not get ahead of ourselves here. The fuse the enforcer mentioned is most likely the problem based on the symptoms. The death was sudden, and after a short in the power line. A fuse is 98% likely to be the culprit.
    I'll deal with on board voltage regulators only when I have to.
  4. #14
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ahh! go on, start dealing with them now
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Packed the screens away for now so I can't look. Might have a look tomorrow when I get them out to play with again.
  6. #16
    Dec 2004
    Baltimore, Maryland
    Hey everyone,
    I haven't fixed this yet, but I did diagnose the problem thanks to all your help.
    It absolutely was the fuse that was blown. I shorted it out and the whole thing powered up just fine. Now I just need to get teh replacement fuse and cram it in there and I'll be all set to go...at least enough tos tart diagnosing whatever's wrong with the rest of the computer. haha
  7. #17
  1. HOLY CRAP.....this is insane
    By cadence117 in forum Off Topic
    Last Post: 06-17-2008, 07:37 PM
  2. Power Supply/OPUS Kill Switch
    By SpaceMonkey in forum Power Supplies
    Last Post: 08-11-2006, 11:58 AM
  3. Lilli only *half* broken.
    By silencery in forum LCD/Display
    Last Post: 04-04-2005, 03:00 PM
  4. Lilli ghosting. Searched and still need help
    By maxxell in forum LCD/Display
    Last Post: 03-24-2005, 04:01 PM
  5. Lilli 7" XP monitor type Won't sync 800x480
    By BMVEE in forum LCD/Display
    Last Post: 03-24-2005, 09:46 AM
