For those unwilling to undertake as much integration as is pictured in this thread, and who don't want to take the monitor apart, I will outline the mounting method that I have used.
I am using the RAM 6"x2" mount with 1" ball, shown here:
http://www.e-mount.com/page_results....=90-02-906-112
Plus a link and a clamp that fits my application. Any of the 1" ball (B size) RAM mount accessories will work.
http://www.e-mount.com/page_results....tring=05002001
With a 6" linkage to a clamp that fits on the side of the center table in my motorhome, the monitor is held rigidly in place, but can be adjusted so that the passenger can see it and it can also be removed in seconds. This stuff is FAR better quality than the stuff I have seen for mounting car stereo equipment in the retail stores.
I attached the 6"x2" plate to the back of the 10.4" monitor, just above the metal slot for the supplied stand, using 3M double-sided automotive trim tape, after cleaning the surfaces with alcohol. That mounting location does not cover any vents, nor does it interfere in any way with the factory stand. It also puts the mounting ball in the center where it provides the best support.
RickD
