Page 57 of 64 FirstFirst ... 7474849505152535455565758596061626364 LastLast
Results 561 to 570 of 638
Thread: GREAT DEAL: 10.4" Touchscreen - Samsung LCD $215!
  1. #561
    Dec 2007
    question for those of you that took this thing apart, on the side of the screen there are 2 wires connected, a pink and blue, they look like they are just connected to the speakers, would i be able to remove these wires without affecting how the screen works other than having no speakers? which i wont use
  2. #562
    Jun 2008
    Wellington, NZ
    Actually those two cables are rather quite important and carry a rather significant charge.
    Popping those cables out will definitely make your screen not work anymore and possibly give you a smelly burning sensation if you close the circuit with you as the bridge
    The only parts that are related to the speakers come from the circuit board and are very easy to identify.
  3. #563
    Dec 2007
    good to know
  4. #564
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    Hey guys, can someone tell me how this connector is supposed to be attached? The header on the board has way more pins than the connector. I know the red wires will be facing the left, but I don't know how many empty pins should be on either side of the connector. This is the 10.4. Thanks.
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
  5. #565
    Dec 2008
    If I remember correctly, you want the spare pins to be on the right and the red wires to be on the left as you said.
  6. #566
    Jan 2006
    Spokane
    Quote Originally Posted by flnole78 View Post
    Thanks. Do you know if I'll short something if I have it wrong?
    MY INSTALLATION LOG
  7. #567
    Jan 2009
    Just make sure the connector is all the way to the left. you will be fine.
    grant
  8. #568
    Dec 2008
    Quote Originally Posted by damarble View Post
    I don't think it will hurt anything but I didn't want to be liable for that answer so I went to the truck and pulled the screen and took pics of mine for you. Hopefully this helps you out.
  9. #569
    Jan 2006
    Spokane
    Thanks guys, looks like all the way to the left is the way to go. Really appreciate the extra effort flnole78. I must have a newer revision though my board looks different than the others in this thread.
    MY INSTALLATION LOG
  10. #570
    Sep 2006
    ok so the 8" screen....what are the dimensions for just the screen.....i've read through all 38 pages of this thread and this answer has not been clearly answered as of yet. one guy was close, but he did not give all the measurements correctly
    6 1/2 H
    1 1/8 W
    1 1/4 D
    i have a hard time believing that the screen is only 1 1/8 inches wide.....
