Page 58 of 64 FirstFirst ... 84849505152535455565758596061626364 LastLast
Results 571 to 580 of 638
Thread: GREAT DEAL: 10.4" Touchscreen - Samsung LCD $215!
  1. #571
    Jun 2008
    Quote Originally Posted by ZoomBy View Post
    ok so the 8" screen....what are the dimensions for just the screen.....i've read through all 38 pages of this thread and this answer has not been clearly answered as of yet. one guy was close, but he did not give all the measurements correctly
    6 1/2 H
    1 1/8 W
    1 1/4 D
    i have a hard time believing that the screen is only 1 1/8 inches wide.....
    What's information do you need? Display size or touch screen size? with plastic or without? I have this machine in hand, and I will take photos to you if you need. More pictures, please visit below link: http://www.onvon.com/inch-touch-scre...itor-p-76.html
  2. #572
    Sep 2006
    thanks for the reply.
    im looking for the physical touch screen size out of the plastic case, but also the dimensions inside of the case as well
  3. #573
    Jun 2008
    TM-8200 VGA touch screen dimension
    Please check the Pictures for TM-8200 VGA touch screen dimension.
    Please ask me to delete after your references.
  4. #574
    Sep 2006
    thanks man, i think its just a tad to high for my car. Im going to have to measure, but thank you. you can remove the pictures now if you want
  5. #575
    Jun 2008
    If two high, there are only one choice for 7 inch, no any smaller size, less than 7 inch the screen is so smaller. please send me some pictures of your car install place, maybe we will have better advise.
  6. #576
    Feb 2009
    Guys,
    I too bought a 10.4" touchscreen display, but its not samsung panel. Can I remove the protective film from this screen. It looks weired.
  7. #577
    Dec 2006
    India
    Quote Originally Posted by ibm_jennifer View Post
    Guys,
    I bought the Shark 10.4" display. Can I remove the protective film from this screen. It looks weired.
    I suggest that you remove the film as the last step in your install incase you are doing some dash moulding and such.
    But before that just make sure it is indeed a protective film and not the touch screen...lol...Needless to say that Shark screen's quality leaves a lot to be desired...
    So the Tata Safari is getting the big screen? Would love to see your install once finished.
  8. #578
    Feb 2009
    OT: Friend, your MySQL Server is down.
    jtablesession::Store Failed
    DB function failed with error number 1146
    Table 'administrator_joom2.jos_session' doesn't exist SQL=INSERT INTO `jos_session` ( `session_id`,`time`,`username`,`gid`,`guest`,`clie nt_id` ) VALUES ( '91e3bad4e4d2bffb3bc90e54c07893cd','1238168708','' ,'0','1','0' )
  9. #579
    Dec 2006
    India
    Hmm...Thanks to recession, my host went bust...Need to move now.
    Now we are seriously offtopic.
  10. #580
    Feb 2009
    Guys,
    The same 10.4" display unit is available here at a very low price. But I am sure, its not Samsung LCD Panel. Should this Samsung LCD Panel worth $50 extra?
    Do you recommend it: http://www.onvon.com/inch-touch-scre...itor-p-79.html
    No, I have no link with this guys(!)
