Results 1 to 10 of 12
Thread: connecting xenarc power wire to molex
    Low Bitrate blackmz3's Avatar
    May 2005
    Grand Prairie, TX
    ok i read how to wire to a molex but i have a problem. im not sure which is power and ground. i bought this xenarc used and they only gave me one wire which looks like this after i remove the covering.
    left: black rubber covering
    middle: white wire with silver strands coming out
    right: silver strands sort of wrapped around the white wire.
    im assuming the white is power and silver is ground. just want to make sure.
    Feb 2006
    Melbourne, Australia
    White is power, silver is ground.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    May 2005
    Grand Prairie, TX
    woot...thanks mr bean.
    Feb 2006
    You're welcome
    Jun 2006
    Yep, this is great. My friend did it and now it;s working off his M2.
    May 2005
    Grand Prairie, TX
    yup, that's what im planning to do.
    2008.5 White MS3 Sport
    Cobb Shifter Weight | Cobb SRI | Cobb AP | Cobb Turbo Inlet
    HKS BOV(Recirc) | Defi Boost Gauge| TRZ Tranny Mount| F2 BSD | F2 Oil Baffle
    Mar 2007
    can you post pictures of how you connected it to your molex? which color molex does it go to?
    I have a M2 ATX power supply as well.
    May 2005
    Grand Prairie, TX
    i will when i get to it. im installing the OS right now. i'm going to solder the white wire to the red wire coming from the molex connector and the silver wire to the black wire from the molex connector.
    Sep 2002
    New Jersey
    The white power should go to the yellow (12v) wire on the molex connector. The red wire is only 5V
    1991 Camaro Z28
    2004 Acura TL
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by SLAYER6669 View Post
    Correct. In case someone searches and does not already know the Black wires on the PC molex connectors are both ground (earth).
    TruckinMP3
    Read the FAQ!
  1. Quality of power, signal, and speaker wire?
    By cherrybomb in forum Car Audio
    Last Post: 01-11-2007, 07:55 PM
  2. 12 Guage power wire???
    By Stillalive2029 in forum Power Supplies
    Last Post: 06-28-2006, 11:04 AM
  3. Newb question about power from a Molex
    By dsballer2000 in forum Power Supplies
    Last Post: 06-25-2006, 12:32 AM
  4. xenarc power question for adding a camera
    By DBrisson in forum LCD/Display
    Last Post: 01-08-2006, 05:56 PM
  5. Opus wont power, green wire has constant 5v???
    By jedi7001 in forum Power Supplies
    Last Post: 02-22-2005, 11:30 AM
