Results 1 to 5 of 5
Thread: Removing Case from Transreflective.
    Newbie PatInTheHat's Avatar
    Jun 2007
    So I believe im going to go ahead and order one of these but I have one nagging concern. It seems very likely that in order to do my install I will need to remove the housing that the LCD comes in. I realize this voids the warranty but are there any other problems/concerns I might encounter by doing this. This is my first Car PC (although I am a fairly tech handy person) and I might be getting a bit over my head here and it would suck to toss away $700 by making a stupid mistake.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    just make sure you dont damage the ribbon connections, just take your time and dont force anything. I took mine apart and moulded it in no probs.. good luck :-)
    Low Bitrate erie's Avatar
    May 2006
    USA
    Also remember that the TS panel for the trans is slighlty thicker that the non-trans TS so be sure not to over tighten the screws that hold the LCD panel. Other than that is just like a standard liliput.
    06 Galaxy Gray Si #0308
    CarPc Progress -
    10%---------50%---------100%
    -[XXXXXXXXXXXXXXXXXXXXXX]-
    Jun 2007
    How much thicker are we talking?
    Feb 2004
    Manchester
    the touchscreen floats above the panel by a couple of mm's, on mine it was all aligned up after by using little white doublesided pads. I just moulded in the front part, then rebuilt the screen back in and even screwed the back case on
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. FS: Casetronic C138 Mini-ITX Case, Black 120W
    By rinroe in forum Classified Archive
    Last Post: 08-15-2006, 03:26 PM
  3. Buy Case Or Build Case
    By setite in forum Newbie
    Last Post: 07-19-2006, 07:31 PM
  4. is frodo compatible with voice software?
    By nappyjim in forum FrodoPlayer
    Last Post: 11-01-2004, 05:50 PM
  5. Mounting the case
    By TheFly in forum General Hardware Discussion
    Last Post: 05-05-2002, 04:11 PM
