Results 1 to 10 of 10
Thread: Do you use your screens buttons?
    Mar 2007
    Central Florida
    Just what the title says.
    I'm doing a double DIN computer and don't have much room. The Lilliput buttons are on a board that is too long for me to put on the side and I don't have room to put them on the top or bottom, so I'm wondering if I even need them.
    Chime in.
    Thanks.
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    I removed the buttons from my lilliput screen. I just extended the IR receiver and use the remote control to adjust the screen whenever I need too.
    The road is long but we are getting there.
    Registered User
    I never use the buttons but i have them glued to the back of my bezel as a backup
    Mar 2007
    before you remove them, make sure you program the hidden auto on/off feature. You need those buttons to do so. The remote control won't work for that process.
    Mar 2006
    Colorado, but Canadian!
    There was a thread here recently about someone who removed their buttons, and then needed them to switch AV inputs. I guess if you turn on then off the screen rapidly or something it may switch av inputs on you. So keep the bezel as a backup somewhere, even if behind the screen, or at a minimum, relocate the IR receiver to a vent. I personally have all the buttons on my screen, but use them only for power. If it is a really dark night, and I am delivering to a bad area, I turn my screen off before I get close. Because when you deliver, you become a target for idiot thieves, and a glow of a big 'ol screen means mega-money to them. They dont know until after they rip it out it is worthless to a pawn shop.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2007
    Central Florida
    Thanks for the info. I will most likely relocate the IR receiver. Although, I just took apart the screen and didn't see one. Of course, I wasn't looking. And I will put the buttons inside somewhere.
    Mar 2007
    Quote Originally Posted by ironfinger View Post
    how do you program the auto on/off feature? just the first time you hook it up?
    Mar 2007
    Quote Originally Posted by Snortonnorton View Post
    for the 701: http://www.mp3car.com/vbulletin/lcd-...ut-eby701.html
    other model(s)
    http://www.mp3car.com/vbulletin/lcd-...ing-guide.html
    I only did it once, right before I installed it into the car.
    _
    Mar 2004
    Little Elm, Texas
    I use the buttons on our screen all the time.
    Dimming at night is crucial...just relying on the front end isn't enough many times.
    Jan Bennett
    Mar 2007
    Central Florida
    Thanks for the reply Red. I'll have to reconsider this.
    Also, I don't understand the auto power on thing. On my bench, when the power is turned off to the power supply, which would be equivalent to turning off the car, the screen has no power. When I turn the power on, the screen buttons light up indicating that it has power, but the screen stays blank. Then when I boot up the computer, the screen jumps to life and displays as normal. I'm pretty sure I don't have to hit the power button on the monitor. So isn't this the way I would want it in the car? Is this auto on mode and I just got lucky? What's the deal?
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 12:45 PM
  2. Replies: 4
    Last Post: 06-28-2007, 10:34 AM
  3. backlit buttons!
    By scott_fx in forum Fabrication
    Last Post: 04-17-2005, 09:31 AM
  4. Multiple Screens? Larger Screens?
    By Atom_Bomb in forum LCD/Display
    Last Post: 03-31-2004, 07:24 PM
  5. Illuminated buttons for custom console
    By mccleanp in forum General Hardware Discussion
    Last Post: 01-18-2002, 10:37 PM
